Differential Equation Help: As t approaches 0, y approaches
The discussion revolves around solving an initial value problem related to differential equations, specifically examining the behavior of a solution as the variable t approaches 0.
  • Participants discuss the form of the solution to the differential equation and the critical value a0. There is an attempt to clarify the behavior of the solution as t approaches 0, with one participant questioning the expansion of the cosine function near this limit.
The discussion includes attempts to clarify the mathematical reasoning behind the behavior of the solution and the use of Taylor expansion for cosine. Some participants are seeking further elaboration on the nature of the expansion, indicating a productive exploration of the topic.
There is an indication that the original poster may have misunderstood the behavior of the solution as t approaches 0, which is a point of contention in the discussion.
TheCarl
http://edugen.wileyplus.com/edugen/shared/assignment/test/session.quest1886032entrance1_N10020.mml?size=14&rnd=1360201586591
(b) Solve the initial value problem and find the critical value a0 exactly.
y = ?​
a0 = ?​
(c) Describe the behavior of the solution corresponding to the initial value a0.
y -> ? as t -> 0​
I got part b correct but I thought I'd put it in here to help speed the process for whoever can help me.
(b) y= -cos(t)/(t^2) + (a*pi^2)/(4t^2)
a0 = 4/pi^2
(c) I would think y would approach 0 as t approaches 0 but that apparently is wrong. This is where I need assistance. Any help is greatly appreciated.
a0 = 4/pi^2
I assume a = a0, so y= (1-cos(t))t-2
Do you know an expansion for cos(t) valid in the vicinity of 0?
I apologize if I seem a bit dense but could you elaborate on your question about the expansion on cos(t)? I'm not entirely sure what you're asking.
Taylor expansion? Power series?
