Calculating Work for Pumping Liquid in a Vertical Cylindrical Tank
  • Thread starter Thread starter whatlifeforme
    Liquid Work
The discussion focuses on calculating the work required to pump liquid from a vertical right circular cylindrical tank measuring 32 feet high and 8 feet in diameter, filled with liquid weighing 62.4 lb/ft³. The incorrect initial calculation yielded 31,948.8 ft-lb, while the correct answer is 1,605,922 ft-lb. Key errors included not accounting for the varying heights of liquid layers and neglecting the area of the cylinder in the calculations. Proper integration techniques and understanding of the physical setup are crucial for accurate results.
  • Understanding of integral calculus, specifically definite integrals.
  • Knowledge of the physical properties of fluids, including weight density.
  • Familiarity with the geometry of cylindrical shapes.
  • Ability to visualize and analyze physical scenarios involving liquid dynamics.
  • Study the principles of work and energy in fluid mechanics.
  • Learn about the application of definite integrals in calculating work done against gravity.
  • Explore the concept of liquid pressure and its relationship with depth in a fluid.
  • Investigate the use of cross-sectional area in volume calculations for cylindrical tanks.
Students in physics or engineering courses, particularly those focusing on fluid mechanics, as well as professionals involved in hydraulic systems and fluid dynamics calculations.
whatlifeforme
A vertical right circular cylindrical tank measures 32 feet high and 8 feet in diameter. It is full of liquid weighing 62.4 lb / ft^3 How much work does it take to pump the liquid to the level of the top of the tank?
h=32
d=8 (radius = 4)
liquid weight = 62.4 lb / ft^3
1. integral (0 to 32) (62.4x) dx
2. (156/5)x^2 | (0 to 32)
3. answer: 31,948.8
actual correct answer: 1,605,922 ft-lb
h=32
d=8 (radius = 4)
This (above) is way off.
Have you drawn a sketch of a typical "layer" of water? Each of the layers has the same volume, and hence the same weight, but a layer at the bottom of the tank has to be lifted all the way to the top, while the layer at the top doesn't have to be lifted at all.
I don't see any accounting for this in your work.
3. answer: 31,948.8
hi whatlifeforme! :smile:
ok-ish, but you haven't used the area of the cylinder! :wink:
10K
12K
