What sort of atmosphere could a rogue planet have?
A rogue planet of Earth's size, if ejected from its orbit, may retain an atmosphere depending on its core heat and gravity. The discussion highlights that while gases like hydrogen, neon, and helium have low liquefying points, their presence in significant amounts is unlikely. The internal temperature of the planet is crucial in determining whether nitrogen and oxygen can remain gaseous. Speculation exists that some rogue planets could maintain a heavy atmosphere, potentially allowing for life, although hydrogen alone would not support Earth-like life forms.
  • Understanding of planetary science and atmospheric composition
  • Knowledge of thermodynamics related to gas states
  • Familiarity with the concepts of gravity and its effects on atmospheric retention
  • Basic knowledge of the elements hydrogen, neon, helium, nitrogen, and oxygen
  • Research the atmospheric retention capabilities of rogue planets
  • Study the thermodynamic properties of gases under varying temperatures and pressures
  • Explore the role of gravity in maintaining planetary atmospheres
  • Investigate the potential for life on planets with non-Earth-like atmospheres
Astronomers, planetary scientists, and astrobiologists interested in the conditions and potential for life on rogue planets.
CCWilson
Let's say that a planet of approximately Earth's size - containing, as Earth does, core heat - were tossed out of orbit. Could it maintain any sort of atmosphere, or would all the component gases liquify and freeze, or be gradually lost to space? If it could retain any atmosphere, what gaseous elements would be most likely?
Astronomy news on Phys.org
Well the planets gravity is what keeps the atmosphere. most of the gases however would solidify. However that would also depend on its internal temperature. The question is highly varied so difficult to answer as their are so many variables involved.
I saw on the internet speculation that some rogue planets - and apparently there are a lot of them in the universe - might be able to retain a heavy atmosphere, enough to allow the possibility of life. However, the gas mentioned was hydrogen, which wouldn't sustain our kind of life, although it might keep the temperature slightly warmer. The gases in our atmosphere with the lowest liquifying/freezing points are hydrogen, neon, and helium, by the way.
But take planet Earth as an example. Any idea whether its internal temperature would be enough to keep nitrogen and oxygen from liquifying? There's not much hydrogen, neon, or helium in our atmosphere.
  • · Replies 24 ·
  • · Replies 22 ·
  • · Replies 24 ·
  • · Replies 21 ·
