Find the area of the surface of the curve obtained by rotating the
The discussion revolves around finding the area of the surface obtained by rotating the curve defined by the equation y = 1 + 5x² from x = 0 to x = 5 about the y-axis. Participants are exploring the appropriate formula and methods for calculating surface area in this context.
  • Mixed
  • Participants discuss the use of the surface area formula involving integration and derivatives. There are attempts to apply u-substitution and product rule, with some expressing confusion about their applicability. Questions arise regarding the correct approach to substitution and integration techniques, including the suggestion of using trigonometric substitution.
The discussion is ongoing, with participants sharing their attempts and expressing confusion about the integration process. Some guidance has been offered regarding the use of trigonometric substitution, but there is no consensus on the correct path forward. Multiple interpretations of the problem and methods are being explored.
Participants note challenges with the integration process and the results obtained from computational tools, leading to further questioning of their methods and assumptions. There is an acknowledgment of the complexity of the problem, with some participants feeling uncertain about their progress.
Lo.Lee.Ta.
"Find the area of the surface of the curve obtained by rotating the.."
1. Find the area of the surface obtained by rotating the curve y= 1+5x^2
from x=0 to x=5 about the y-axis.
2. I thought to find surface area, we would need to use this formula:
SA= ∫2[itex]\pi[/itex](f(x))√(1 + (f'(x))2)]dx
3. So far I have:
∫0 to 5 of 2[itex]\pi[/itex][(1 + 5x2)(√(1+100x2))]dx
I first tried to do a u substitution for what's in the square root (1 + 100x2), but then du only equals
200x... And I'm not able to replace the 5x^2...
So it looks like u substitution will not work.
So then I thought I might be able to use the product rule.
So I did:
SA= ∫2[itex]\pi[/itex][(1+ 5x^2)(1/2(100x^2)-1/2)*200x + ((1+100x2)1/2)(10x))]dx |0 to 5
But when I plug in 5 and 0 from here, I get a large number.
The number I get is 7521[itex]\pi[/itex].
But when I put this integral into Wolfram Alpha, it says the answer is an even larger number: 49,894!
I am confused as to what I am doing wrong!
Please help!
Thank you so much! :)
from x=0 to x=5 about the y-axis. 2. I thought to find surface area, we would need to use this formula:
SA= ∫2[itex]\pi[/itex](f(x))√(1 + (f'(x))2)]dx3. So far I have:
∫0 to 5 of 2[itex]\pi[/itex][(1 + 5x2)(√(1+100x2))]dxI first tried to do a u substitution for what's in the square root (1 + 100x2), but then du only equals
So it looks like u substitution will not work.So then I thought I might be able to use the product rule.
So I did:
SA= ∫2[itex]\pi[/itex][(1+ 5x^2)(1/2(100x^2)-1/2)*200x + ((1+100x2)1/2)(10x))]dx |0 to 5But when I plug in 5 and 0 from here, I get a large number.
Please help!
There is no real product rule for integrals, I'm not sure what you are thinking there. But to do the integration you need a trig substitution. Like 10x=tan(t).
=_=! Oh wow, I don't know what I'm thinking either! Of course product rule can't be used for integrals! Ugh. wow.
Okay, so you say that a trig substitution has to be used.
But how can we replace 10x with tan(x)?
So do you mean that in (√1 + (10x)2), we replace the 10x with tan(x)?
...And how would that help us?
Thanks!
Thanks!
You don't just replace 10x with tan(x)! This is u-substitution, tan(u)=10x. The sqrt(1+100x^2)=sqrt(1+tan(u)^2)=sqrt(sec(u)^2)=sec(u). And, of course, you also need to figure out how du is related to dx. The usual substitution routine.
Hmmmm.
I think I see what you mean now about the tan(u)=10x for the u substitution.
tan(u)=10x
u= arctan(10x)
du=(1/((10x)2 + 1)*10dx
du= 10/(100x2 + 1)dx
I need to make the dx side have an x^2!
(100x2 + 1)du = 10dx
(1 + (1/100x2)du = (10/100x2)dx
50x4*(1 + (1/100x2))du = (1/10x2)dx *50x4
(50x4 + 1/2x2)du = 5x2dx
Well, I got a 5x2 on one side, but this does not help me at all because I still have x's on the other side! X(
Ugh, please help me here. :/
I don't see how I can do a u substitution.
_____________________________________________________
∫0 to 5 of 2[itex]\pi[/itex][(1 + 5x2)(√(1 + (10x)2))]dx
= ∫2[itex]\pi[/itex][(1 + 5x2)(√(1 + (tan(u))2))]dx
So, I haven't finished my u substitution because I cannot get it to work...
Thanks for the help!
And it looks the 49,894 answer I got from Wolfram Alpha is wrong...
No, it's not wrong. You just aren't following through with whole program. You were supposed to convert the integral to a du integral. If tan(u)=10x then sec^2(u)du=10dx. It's maybe somewhat easier if you substitute 10x=sinh(u) if you know hyperbolic trig functions. But it's not supposed to be a very easy problem.
  • · Replies 20 ·
