Is the reaction between water & hydrochloric acid an neutralization ?
The discussion revolves around whether the reaction between water and hydrochloric acid can be classified as a neutralization reaction. Participants explore definitions of acid-base reactions, the role of water, and the implications of proton transfer in this context.
  • Some participants propose that hydrochloric acid (HCl) acts as the acid and water as the base, suggesting that the amount of H2O relative to HCl could determine the solution's acidity.
  • Others argue that when HCl is dissolved in water, it produces hydronium ions (H3O) and chlorine ions, leading to a decrease in pH, indicating an acidic solution.
  • A participant questions the classification of the reaction, asking if it should be termed an acid-base reaction instead of a neutralization reaction.
  • Another participant asserts that an acid-base reaction is a form of neutralization, citing the production of water and sodium chloride when HCl reacts with sodium hydroxide.
  • Some participants express uncertainty about the terminology, suggesting that the reaction could be described as protonation of water molecules or simply an acid/base reaction without forming an ionic compound.
  • One participant introduces the concept of dissociation, questioning if all acid or base reactions in water could be classified as such.
  • A later reply emphasizes the distinction between acid-base reactions and neutralization, noting that water serves as a solvent and does not contribute to the formation of ions in the same way as other bases.
Participants do not reach a consensus on whether the reaction between water and hydrochloric acid should be classified as a neutralization reaction. Multiple competing views regarding the definitions and implications of acid-base reactions and neutralization remain present throughout the discussion.
Participants reference differing definitions of acid-base reactions and neutralization, highlighting the importance of context in chemical reactions. There are unresolved questions regarding the implications of proton transfer and the role of water as a solvent.
mcfaker
Hi,
Hydrochloric acid is the acid & water would be considered the base.
Also does this mean that if there are more H20 molecules the solution would be considered a base?
And if we have more HCl molecules than H20 this means the solution could be considered acidic?
If so is it possible to dissolve more HCl molecules then there are H20 molecules in H20, so we would acquire an acidic solution?
Thanks in advance!
That's not the way acids work. When HCl is dissolved in water, a positive hydronium ion (H3O) is produced along with a negative chlorine ion.
The pH value of water is 7.0 Adding even a small amount of HCl to the water would reduce the pH below 7.0, or to the acidic side.
Thanks for the help! But how do we then call the reaction? So if its not a neutralization reaction, is it an acid-base reaction?
An acid-base reaction is a neutralization.
Look at it this way. Dissolving HCl and say sodium hydroxide in water facilitates their reaction, which produces more water plus sodium chloride. The water can be removed and only the sodium chloride remains.
I am not sure there is a "name" for this reaction. If anything, we can speak about water molecules protonation.
can we call it an acid base reaction?, because the definition(in my book) of an acid base reaction is: Proton transfer between the reactants.
Meanwhile the definition(in my book) of a neutralization is the reaction of an acid with a base with a formation of an ionic compound (sometimes with water)!
There is no formation of an ionic compound so its not a neutralization reaction. We could call it a proton transfer or just a acid/base reaction. Do I make any sense? :D
Wouldn't any acid or base in water reaction be called dissociation?
negative
Going by a strict definition of a BL acid or base the dissociation of HCl in water can be classified as an acid base reaction because there is a proton donor and acceptor. The difference between that and a neutralization reaction is that water is the solvent in both cases. It acts more as the medium into which the protons or hydroxides disperse and go on to interact and zoom around etc. It may seem trivial but is nevertheless an important distinction to chemists. They are treated very differently in qualitative and quantitative aspects.
You cannot do acid base titrations with pure water because it is not a good source of ions. There are only 100nmol of hydrogen ions per liter of water. Imagine trying to titrate 1L of a 0.02M HCl solution with pure water. What you are really doing is diluting the solution, not neutralizing. At some point you just dilute so much of the HCl that you are back to water with some contaminants and very near pH 7.
