Measuring Length with Oscillating Rods
  • Context: Graduate
  • Thread starter Thread starter satyudhi
    Length Measure
The discussion centers on measuring the length of an oscillating rod system in the context of special relativity. When a fixed rod and an oscillating rod are attached, the imprint left on sand by the oscillating rod appears to match the proper length of the system, despite relativistic effects. The key conclusion is that the imprint reflects the proper length in all frames, contradicting the expected length contraction. Accurate measurement requires synchronization of clocks at different positions to account for relativistic time dilation.
  • Understanding of special relativity principles
  • Knowledge of proper length and length contraction
  • Familiarity with oscillatory motion
  • Basic concepts of time synchronization in physics
  • Study the implications of length contraction in special relativity
  • Learn about the synchronization of clocks in different reference frames
  • Explore oscillatory motion and its mathematical modeling
  • Investigate experimental setups for measuring relativistic effects
Physicists, students of relativity, and anyone interested in the implications of oscillatory motion in relativistic contexts.
satyudhi
I take a rod and attach to its ends a another rod parallely at a distance r. The second rod oscillates about the first one through 180 degrees with some time period 't'. Now I am in a frame in which this system is moving at a speed 'v' with respect to me. I keep some sand in the way of this system. So when the rod passes over this sand, there will be 2 imprints left, one is the straight line which is the trajectory of our fixed rod while the other is the imprint of the osscilating rod when it struck the sand. This imprint will be of the same lengh as the oscillating rod as the whole (osscillating) rod struck the sand at once. But the oscillating rod is of the same length as the length of the fixed rod, as it it tied at the ends. So in principle the length of the imprint must be equal to the proper length of rod(system). But then this metod of length measurement gives me proper length in all frames, rather than a contracted length. So what will eb the length of the imprint actually?
In your reference frame the rod does not have proper length. Anyways, you need to be precise by what you mean "struck the sand at once". In special relativity you will need two clocks (in your reference frame)at different positions measuring the end points at the same time.
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 35 ·
  • · Replies 84 ·
  • · Replies 23 ·
  • · Replies 78 ·
