New Reply
Cauchy dispersion formula
Share Thread Thread Tools
Feb18-13, 08:02 AM   #1
Hi everybody,
I would like to use the 'cauchy dispersion formula', ie (http://en.wikipedia.org/wiki/Cauchy's_equation):
eta = A + B / w²
Where :
eta is the resulting IOR
A is the base IOR
B is the dispersion coefficient expressed in squarre meter (m²)
w is wavelength expressed in micro-meters
I try to apply this formula this way :
B = 0.013 in micro-meters,
A = 1.72
So first,
1) I convert the B parameter from micro-meter to m² : B = B / 1000000
2) I convert my wavelenght from nm to micro-meter : wv = 500 / 1000
But the result I got seems incorrect, I got no dispersion !!!
Maybe there is a problem with my units ?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Feb18-13, 08:11 AM   #2
Mentor
Quote by spectral View Post
1) I convert the B parameter from micro-meter to m² : B = B * 1000000
I think you mean to convert B's units from m2 to (μm)2. For that, you have to multiply by 10000002, not 1000000.
Feb18-13, 08:38 AM   #3
Thanks for your answer,
But based on the formula here :http://en.wikipedia.org/wiki/Cauchy's_equation
the C parameters (I use B instead) is expressed in micro-meters !!!!
So, if C = 0.013 in micro-meters I have to convert it to meters to use the Cauchy formula...
... then I "divide" by 1000000² ?
Or there is something wrong in what I do or my units ?
Thanks
Feb18-13, 08:41 AM   #4
By example, I should have :
eta = 1.72 + (0.013 / 1000000²) / 0.500²
Feb18-13, 09:25 AM   #5
Mentor
OK, I see now. I didn't look at the Wikipedia page to see where the numbers came from before.
If your B (their C) is already in units of (μm)2, and you've converted your wavelength λ to μm, then the quantity B / λ2 = 0.013 / 0.52 has units of (μm)2/(μm)2, i.e. it's unit-less, as it should be because the index of refraction is unit-less. Why do you want to convert B to m2?
Feb18-13, 09:37 AM   #6
I see...
It is just that I have see somewhere that the C parameter has to be in m²... but it seems false !
Thanks for your help
Feb18-13, 09:52 AM   #7
Mentor
I suspect that they do their calculations using λ in meters.
New Reply
Thread Tools
Similar Threads for: Cauchy dispersion formula
Thread Forum Replies
Cauchy Integral Formula Calculus & Beyond Homework 1
cauchy's formula Calculus & Beyond Homework 1
integral with cauchy formula Calculus & Beyond Homework 1
Using Cauchy's integral formula Calculus & Beyond Homework 0
Consequences of Cauchy's Formula (differential formula) Calculus & Beyond Homework 1
