Evaporation of h202 in a h20 solution
  • Context: High School
  • Thread starter Thread starter captvancouver
    Evaporation
The discussion centers on the evaporation of hydrogen peroxide (H2O2) in a water (H2O) solution, specifically a mixture of 1% H2O2 and 99% H2O. It is established that H2O2 and H2O evaporate at different rates, which affects the composition of the vapor produced. Pouring this solution into a petri dish and using a fan to direct airflow over the surface will not yield a gaseous solution with the same 1% H2O2 concentration due to the differing evaporation rates. Complete evaporation of the liquid is necessary to achieve the desired gas concentration.
  • Understanding of chemical properties of hydrogen peroxide (H2O2) and water (H2O)
  • Knowledge of evaporation processes and rates
  • Familiarity with gas concentration calculations
  • Basic laboratory safety practices when handling chemicals
  • Research the evaporation rates of hydrogen peroxide compared to water
  • Learn about gas concentration calculations in mixtures
  • Explore methods for achieving controlled evaporation in laboratory settings
  • Investigate the effects of airflow on evaporation rates of liquid solutions
Chemistry students, laboratory technicians, and anyone involved in chemical handling or gas generation processes.
captvancouver
I need to make a gas consisting of 1 % h202. Would pouring a liquid consisting of 1% h202 and 99% h20 into a pitre dish ,and using a small fan directed at the surface result in a gaseous solution of 1% h202. The answer seems simple to me, but I have no background ,and am usually wrong in these matters.
Science news on Phys.org
In general, H2O2 and H2O can evaporate at different rates (well, they will do, the question is just how different the rates are). If you evaporate everything, it should be fine, however.
Think about it - if the vapors above the liquid had the same composition the liquid has, you won't be able to drink anything stronger than wine.
High School Potato paradox
  • · Replies 28 ·
10K
  • · Replies 131 ·
11K
