Higgs Boson = Universe is False Vacuum?
The discussion centers on the implications of the Higgs boson discovery, suggesting that the universe may exist in a 'false vacuum' state. The stability of the Higgs vacuum is determined by the quartic term, λh4, where a positive λ indicates a true vacuum and a negative λ suggests an unbounded potential, leading to a false vacuum scenario. The analysis involves running the value of λ(Mt) to large scales, with the stability of the vacuum contingent on whether λ becomes negative before reaching the Planck scale. Both Alekhin et al. and Degrassi et al. papers provide similar stability bounds, though with differing uncertainties regarding the top quark mass.
  • Understanding of Higgs potential and vacuum stability concepts
  • Familiarity with quantum field theory and the Standard Model (SM)
  • Knowledge of renormalization group equations and their implications
  • Basic grasp of particle physics parameters, particularly Yukawa couplings and top quark mass
  • Study the implications of the Higgs mechanism on vacuum stability
  • Examine the renormalization group running of coupling constants in quantum field theory
  • Review the detailed calculations in Alekhin et al. and Degrassi et al. papers regarding vacuum stability
  • Explore the significance of the Planck scale in particle physics and cosmology
Physicists, researchers in particle physics, and students studying quantum field theory who are interested in the implications of the Higgs boson on the stability of the universe.
Jarwulf
The question of stability of the Higgs vacuum has to do with the shape of the potential, in particular, with the sign of the quartic term, [itex]\lambda h^4[/itex]. If [itex]\lambda[/itex] is positive, then the potential is bounded from below, so that there is a true vacuum at a finite value of the Higgs field, [itex]\langle h \rangle = v[/itex]. This is the case that is usually drawn when people discuss the Higgs mechanism. If [itex]\lambda[/itex] is negative, then the potential is unbounded from below and there is no global minimum. Depending on the quadratic and other terms, there can be a local minimum, which is the false vacuum. Given a long enough period of time, we can have tunneling through the barrier, after which the Higgs field value rolls off to infinity. If the tunneling time is sufficiently long (the age of the universe is the relevant scale here), we can call the vacuum metastable.
At lowest order (tree-level), the coefficients in the Higgs potential can be determined from the weak coupling constant and W/Z and Higgs masses. However, because of quantum effects, the coefficients actually "run" with energy scale according to the renormalization group. Large Higgs value corresponds to a large energy scale (the Higgs field h has units of mass), so the renormalization corrections can get large compared to the tree-level terms. The corrections can be determined in terms of parameters like the masses of all of the other particles participating in the SM interaction, especially the top quark. A detailed formula for the running of [itex]\lambda[/itex] is eq (52) in http://arxiv.org/abs/1205.6497, which is cited in the Alekhin et al paper you linked to. This formula depends on technical details like Yukawa couplings and anomalous dimensions. The formula (63) is a simpler looking formula that boils experimental data into a value for [itex]\lambda(M_t)[/itex] at the scale set by the top quark mass.
The relevant analysis is then to take the value of [itex]\lambda(M_t)[/itex] given by (63) and then use (52) to run its value to large scales. If the sign goes negative before reaching the Planck scale, then the vacuum is not stable. If the tunneling time is longer than the present age of the universe, we distinguish the vacuum as metastable. I'm not 100% certain what Alekhin et al have done differently other than extract a value for the top quark pole mass that has a much larger uncertainty than the one considered by Degrassi et al. Both papers find the same stability bound, but of course the Alekhin et al result has a larger error bar.
