Poisson vs Binomial distribution.
The discussion focuses on the application of the Poisson distribution as an approximation for the Binomial distribution in statistical problems. Specifically, it addresses a scenario where the probability of a side effect from a flu vaccine is 0.005, and 1000 individuals are inoculated. The participants conclude that when the number of trials (n) is large and the probability of success (p) is small, the Binomial(n, p) distribution can be approximated by the Poisson(np) distribution. This approximation simplifies calculations, especially when dealing with large factorials in Binomial coefficients.
  • Understanding of Binomial distribution
  • Familiarity with Poisson distribution
  • Basic knowledge of probability theory
  • Experience with statistical computation methods
  • Study the conditions for using Poisson approximation in detail
  • Learn about the properties of Poisson distributions, including the sum of independent Poisson variables
  • Explore computational techniques for Binomial coefficients to improve efficiency
  • Investigate the historical context of statistical methods and their evolution
Statisticians, data analysts, and students in probability and statistics who are looking to understand the practical applications of Poisson and Binomial distributions in real-world scenarios.
Jcampuzano2
Hello PF
This might be a fairly simple question to most of you, but I was given this problem (don't worry, I already solved it just wondering about something)
Suppose the probability of suffering a side effect of a certain flu vaccine is 0.005. If 1000 persons are inoculate, find the approximate probability that
(a) at most 1 person suffers, (b) 4,5, or 6 persons suffer.
I already solved it, but this problem is in the chapter on the Poisson distribution. Unfortunately my teacher didn't cover this distribution in detail, but when I first looked at the problem it look like a typical Binomial distribution problem? I later figured out I was supposed to approximate with the Poisson distribution.
Why would we use an approximation for the Binomial when we could just apply it, and under what circumstances am I allowed to make this approximation in the first place?
The problem with the binomial distribution is that it is very hard to calculate.
So the second question would be
[tex]\sum_{k=4}^6 \binom{1000}{k} (0.005)^k0.995^{1000-k}[/tex]
This is the correct answer. But computing those binomial coefficients is not very fun.
However, we can show that if we are working with binomial(n,pn) distributions and if [itex]np_n\rightarrow \lambda[/itex] for some [itex]\lambda[/itex], then
[tex]\binom{n}{k} p^k (1-p)^{n-k} \rightarrow e^{-\lambda} \frac{\lambda^k}{k!}[/tex]
So, if n is very large and p is very small, then the Binomial(n,p) distribution is very close to the Poisson(np) distribution.
So, in our case, p=0.005 is small and n=1000 is large. The product is medium: 5. So we can approximate the answer by
[tex]\sum_{k=1}^6 e^{-5} \frac{5^k}{k!}[/tex]
And we are also rid of that pesky binomial coefficient.
This approximation is also theoretically interesting. The sum of two (independent) Poisson distributions is always a Poisson distribution, for example. But the sum of two (independent) binomial distributions is not binomial.
Jcampuzano2 said:
Hello PF
Partly it is holdover from the old days when computation was expensive. The teaching of statistics hasn't changed much in the past 50 years, as far as I could tell. The binomial is still tricky to compute because the factorials in the intermediate results can be very large and you have to be careful not to get computer overflow.
You can use the Poisson approximation when n is large (greater than 50 is probably enough) and when the chance of 0 successes or n successes is negligible. It depends on how much accuracy you need, so there can be no hard and fast rule.
