Diameter of a stream of water from a faucet
The problem involves analyzing the flow of water from a kitchen faucet, specifically determining the diameter of the water stream at a certain distance below the faucet. The initial diameter and flow rate are provided, along with relevant equations from fluid dynamics, including the equation of continuity and Bernoulli's equation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using the flow rate and initial diameter to find the initial velocity and then applying Bernoulli's equation to find the diameter at a lower point. There are questions about the pressure difference and assumptions regarding atmospheric pressure. Some participants express confusion over the calculations and the expected results.
The discussion is ongoing, with various participants providing insights and calculations. Some have offered guidance on applying Bernoulli's equation and continuity, while others are questioning the assumptions made about pressure differences. There is no clear consensus on the correct approach or final answer, as multiple interpretations and calculations are being explored.
Participants are considering the effects of pressure differences due to height changes and velocity increases in an open system. There is mention of potential round-off errors and the importance of unit consistency in calculations.
sluo
Consider a stream of water flowing from a kitchen faucet. At the mouth of the faucet, the diameter of the stream is 0.960 cm. The stream fills a 125 cm^3 container in 16.3 seconds. Find the diameter of the stream 13.0 cm below the mouth of the faucet.
Equation of continuity: A_1v_1 = A_2v_2
Bernoulli's equation: P_1 + 0.5ρv_1^2 + ρgh_1 = P_2 + 0.5ρv_2^2 + ρgh_2
Ok, so using the flow rate and the diameter at the mouth of the faucet we can solve for v_1. We can then write v_2 = (A_1v_1)/A_2 and plug this into Bernoulli's equation and solve for A_2 from which we can extract the diameter. My main question is what is the pressure difference? I assumed P_1=P_2 and from this I got an answer that is close to what the book gives, but not close enough for me to think I'm doing it right. Can anyone tell me what the pressure difference ought to be and why? Thanks!
I would think that the main cause of a pressure difference from atmospheric would be from surface tension, but it doesn't sound like you should be taking that into account.
Please post the details of your working and the book answer.
I don't see why there should be a pressure difference. p = 1 at. at A1 and A2. Roundoff error? Converted 125 cm3 correctly into m3?
Since the water stream "descended" a little, a pressure difference will form due to the gain in velocity.
Remember Bernoulli's equation:
Suppose the initial velocity was v_1, and take the faucet's height to be at relative level 0; Then surely:
[tex]\frac{\rho {v_1}^2}{2}=\rho \frac{{v_2}^2}{2} - \rho gh[/tex]
Then use continuity.
And you are given parameters to find out the initial velocity(v_1):Recall the relations between volume, speed, and area.
(Is the correct answer, by the way, 0.245 cm?)
danielakkerma said:
Since the water stream "descended" a little pressure difference due to the gain in its velocity.
This is in open air. Why, other than surface tension, would the pressure at any point differ from atmospheric?
The book lists the correct answer as 0.247 cm. I keep getting 0.268 cm. It seems from your equation above, that you took P_1 = P_2 even though you said that there should be some difference. So is there a pressure difference or not?
Here is my work:
[tex] A_1v_1 = 125 cm^3/ 16.3 s \\<br /> v_1 = 125/(16.3 *\pi*0.48^2) = 10.6 cm/s[/tex]
Next, write [tex]v_2 = A_1v_1/A_2[/tex] and plug into Bernoulli's equation. If we take [tex]P_1 = P_2[/tex], then the density cancels out and it simplifies to
[tex] 2gh = v_2^2 - v_1^2 = \Bigg(\frac{A_1^2}{A_2^2} - 1\Bigg)v_1^2[/tex]
From this we get
[tex] A_2^2 = \frac{A_1^2}{\frac{2gh}{v_1^2} + 1}[/tex]
Plugging in values, we have
[tex] A_2^2 = \frac{\pi .48^2}{\frac{2*980*13}{10.6^2} + 1} = .00319[/tex]
So
[tex] A_2 = .05698 = \pi r^2[/tex]
Solving for r and multiplying by 2, I get 0.268 cm. The book says 0.247 cm is the correct answer.
What gives here? You cite the Bernoulli equation without pressure appearing in it, thereby contradicting yourelf!
I went thru the op's math & came up with the same answer. daniel?
Try ##A_2^2 = \frac{\left(\pi .48^2\right)^2}{\frac{2*980*13}{10.6^2} + 1}##
I think you got 2.68cm.
Sorry, I must have misunderstood...
There is obviously no external pressure variation.
For some reason I thought you were referring to the change in Dynamic pressure, which obviously exists.
Apologies all around!
And it seems you have done everything correctly.
Not so - see my previous post (#10)
I see what you mean, though through your method, one still gets 0.268 cm, which the OP stated is incorrect.
But, if you do this:
[tex]v_1 = \frac{V}{A_1 t} \approx 10.5947 \ \frac{cm}{s} \\<br /> {v_2} = \sqrt{{v_1}^2+2gh} \approx 159.976 \ \frac{cm}{s} \\<br /> A_2 = \frac{A_1 \ v_1}{v_2} \approx 0.0479367 \ {cm}^2 \\<br /> d_2 = 2\sqrt{\frac{A_2}{\pi}} = 0.247 cm[/tex]
Which is what the OP wanted to obtain...
OK, so no roundoff error!
Thank you, yes I was forgetting to square the A_1. And the answer is .247cm, not 2.47cm. I kept everything in cm throughout. Thank you!
It was never a round-off error; it was out by an order of magnitude.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 30 ·
