Finding Volume of Solid of Revolution around Y-Axis
  • Thread starter Thread starter lionely
    Revolution Solids
The discussion revolves around finding the volume of a solid generated by rotating the curve defined by the equation y = 1 - x³ around the y-axis, bounded by x = 0 and y = 0. Participants are exploring the integration process and the correct application of limits in the context of this solid of revolution problem.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the setup of the integral for volume calculation and the substitution of limits. There is an exploration of the antiderivative and its evaluation at the specified bounds.
The discussion has progressed with participants identifying potential errors in the substitution process. Some have confirmed their calculations and shared their results, indicating a shift towards resolving the initial misunderstanding.
There is mention of a common oversight regarding the treatment of the lower bound in integration, particularly when it is zero. This reflects a broader concern about assumptions made during the calculation process.
lionely
Find the volume of the solid generated by rotating about the y-axis
y= 1-x3 x=0 , y=0
I tried sketching the graph of y= 1-x^3 then tried to find the volume from y=1 to y=0.
if x^3 = 1-y
x= (1-y)1/3
so x2= (1-y)2/3
∏∫x2δy
=> ∏∫(1-y)2/3.dy = ∏[ -3/5(1-y)^(5/3)]
I did that for y=1 to y=0.
But I can't get the right answer.
I got 0pi
but the answer should be 3pi/5
It would be helpful if you told us what answer you got and what answer you are supposed to get.
I edited it
The antiderivative looks right, so it looks like the error is in substituting the y = 1 and y = 0. Double check your work.
omg I'm so stupid I didn't do the one for 0, because most times when it's 0 I ignore it. Bad a habit. I got 3/5pi now
lionely said:
∏[ -3/5(1-y)^(5/3)]
What did you get for each bound (y=0, y=1)?
I got it now!
  • · Replies 40 ·
  • · Replies 27 ·
