Register to reply
Angular Momentum of a sliding disc about a point on the floor
by naes213
Tags: angular, disc, floor, momentum, point, sliding
Share this thread:
naes213
#1
Feb20-13, 06:21 PM
P: 20
Hi everybody,
A seemingly straightforward example from lecture is causing me some confusion. The example was about calculating the angular momentum of a sliding disk (not rolling) about a point on the floor. The result given in lecture says the distance to the point on the floor is unrelated to the angular momentum:
[tex]\vec{L}=\vec{r} \times \vec{p}=\sum{\vec{r}_i \times \vec{p}_i}=\sum{\vec{r}_i \times m_i\vec{v}_i}=MRv [/tex]
where M is the total mass of the disc, R is the radius of the disc, and v is the translational velocity of the sliding disc. Now my confusion comes in at the last equal sign. I think it should read:
[tex]\sum{\vec{r}_i \times m_i \vec{v}_i}=\sum{m_i r_i v_i \sin{\theta_i}}[/tex]
where [itex]\theta_i[/itex] is the angle between each particles radius vector and the constant velocity vector. I don't see how this sum ends up as [itex]MRv[/itex] as was claimed in lecture.
I tried to write [itex] \theta_i [/itex] as a function of each ri and integrate over the disc, but didn't make progress. I know I can take the mi and vi out of the sum because they are the same for each i, but I still can't deal with the
[tex]\sum{r_i\sin{\theta_i}}[/tex]
Any help would be greatly appreciated! Maybe I'm just missing something really obvious, I don't know.
Thanks,
Sean
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
Nature's designs inspire research into new light-based technologies
UCI team is first to capture motion of single molecule in real time
tiny-tim
#2
Feb21-13, 08:35 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Hi Sean!
Quote Quote by naes213 View Post
No, R is the perpendicular distance from the point to the line of motion of the centre of mass.
ri x mi vi
= (∑ miri) x v since vi = a constant, v
and then use ∑ mi(ri - ro) = 0 by definition, where ro is the centre of mass
naes213
#3
Feb21-13, 12:50 PM
P: 20
Ok, I see. That makes sense. In my situation it just so happens that the perpendicular distance is equal to the radius of the disc. In a more general scenario this would be different. Thank you!
Register to reply
Related Discussions
Point of application of angular momentum Introductory Physics Homework 12
Angular momentum about an Axis and a Point Introductory Physics Homework 7
A Block Sliding Across the Floor Introductory Physics Homework 4
What is the point of angular momentum? Classical Physics 6
Angular velocity and period of a disc rotating about point on circumference Introductory Physics Homework 2
