Theoretical Physics: What's the Point & How Is It Accurate?
The discussion revolves around the nature and validity of theoretical physics, questioning its purpose, accuracy, and the relationship between theory and experimental verification. Participants explore the implications of theoretical models in understanding physical phenomena and their applicability in real-world scenarios.
  • Some participants question the reality and purpose of theoretical physics, suggesting it deals with concepts that may be unknowable until applied.
  • Others argue that theoretical physics is a legitimate field that develops models based on observations and can make testable predictions.
  • A participant emphasizes that theories can explain previously unexplained phenomena and that their accuracy is determined by their predictive power.
  • There is a distinction made between theories and laws, with some participants asserting that laws describe phenomena while theories explain them.
  • Some contributions highlight that certain theories, like time dilation or elementary particles, were proposed before experimental verification, raising questions about their status as "hard" science.
  • Participants discuss the evolution of theories and the necessity for corrections or augmentations to fit broader scenarios, such as in the case of electron scattering.
  • Examples of theoretical concepts leading to practical applications, such as improved imaging techniques, are provided to illustrate the relevance of theoretical physics.
  • There is contention over the interpretation of Newton's Laws, with some asserting they are not theoretical while others argue they serve as a good approximation within certain contexts.
Participants express a range of views on the nature of theoretical physics, with no clear consensus on its validity or the implications of its models. Disagreements persist regarding the definitions and distinctions between theories and laws, as well as the status of certain theoretical concepts.
Some arguments rely on philosophical interpretations of what constitutes "reality" in theoretical physics, and there are unresolved questions about the applicability and testability of certain theories. The discussion also reflects varying perspectives on the relationship between theoretical predictions and experimental validation.
babysnatcher
Is theoretical physics a real thing? What's the point of doing something that is relatively unknowable? How are such things researched, quantified, and calculated? And why is it accurate? Isn't it unknown until its actually applied?
You seem to be asserting that ideas do not exist. That's a strange idea!
Are you just trolling or what? I don't understand.
"Theoretical" doesn't have to mean "relatively unknowable". Theories can make predictions that can be tested by experiments, or successfully explain previously unexplained experimental results, or most often both. If a theory doesn't do this it generally don't get a lot of attention/interest, for basically the reason that you gave: What's the point?
For example, Einstein's General Relativity was (and still is) pure theoretical physics. But it neatly explained the previously observed but inexplicable precession of Mercury's orbit; and it predicted that light would be deflected in a particular way by gravity, and (after a few false starts) exactly that deflection was observed.
Its a model and is used to predict things out there in reality - how good it is at that is a matter for experiment.
If you count a model as a real thing and issues of that type belong to philosophy where reaching a consensus on anything is well known to be pretty close to impossible.
Think back to good old Euclidean Geometry. Its relation to the real world and issues like you raise is the paradigm for all modern physical theories.
Thanks
Bill
Yes, it is a real activity.
Theoretical physics is not about 'unknowable'. Theoretical physics is about developing conceptions or models about Nature and various observed physical phenomena. Theoretical physics goes hand-in-hand with experimental and applied physics. Theories (and models) are developed based on observation (experiment), and then we make predictions about further/future observations, or behaviors in new experiments based on different inputs.
It either explains the observables or it makes measurable predictions, or it doesn't.
Conceptions/predictions start before new observations/experiments.
I always think of theoretical physics as a model. We're finding simpler model to explain the universe, and some uses existing model to expect behaviour of certain system.
Newton's Laws is one example of "theoretical physics".
The OP is probably confusing the word "theory" used in science with the pedestrian use of the same word. In the latter, it often means an substantiated guesswork. In science, a theory is often a mathematical description of a principle or a phenomenon, and it if often based on verified experimental observations. We often use the description "theoretical physics" to differentiate it from "experimental physics". It has nothing to do with theoretical physics being "unknowable", which is utterly a silly description.
Zz.
I think the OP may mean, that some modern topics in theoretical physics are unknowable/untestable, and therefore not really "hard" science.
Some theories or more precisely their "spin-off consequences" predate experimental verification, like time dilation, the existence of a slew of elementary particles or the CMB.
Other theories are born out of experimental facts, like some of the first ideas in quantum mechanics, or Newton's laws of motion.
Sometimes theories require corrections or augmentations so they work in broader scenarios, like electron scattering in non-relativistic and relativistic regimes; ie: motivations behind the Klein-Nishina cross section for Compton scattering, when the classical electron cross section was failing to produce the observed experimental results. The KN formula provides a more general expression that works for both scenarios.
An example of theory turned into practice.
A new technique allows improved acoustic imaging of oil deposits and other underground structures and may also work for medical imaging.
A new algorithm will allow a cleaner view of subterranean structures using sound waves. A team that previously proposed an imaging technique for an idealized arrangement of geological layers now presents a generalized theory that would be practical for almost any situation. Their technique should allow improved imaging of underground water reservoirs, plumes in the earth’s mantle, or even non-geological systems, such as the innards of airplane wings or human bodies.
http://physics.aps.org/articles/v6/21
Three-Dimensional Single-Sided Marchenko Inverse Scattering, Data-Driven Focusing, Green’s Function Retrieval, and their Mutual Relations
http://prl.aps.org/abstract/PRL/v110/i8/e084301
Not trying to just be mean but just so OP is not confused Newton's Laws are not theoretical that would imply that they are a theory, as in the name Newton's Laws there is a distinct line between laws and theories. A law is merely stating what occurs in a certain phenomena and a theory explains why this phenomena happens.
Newton's "laws" are a good approximation.
I don't think so. Two ways I like to reconcile the "law" in Newton's Laws... One: The term came about when modern science was less developed and the notion that all conclusions are tentative with respect to evidence was not in the forefront of the philosophy of science. Two: The mathematical equation or theorem is the "law". The mathematical equation or theorem is always true with respect to it's axioms, hence its a law. But when we want to claim that this equation models observations then that is a theory. Its a scientific theory that Newton's Laws model our observations and provide predictive power.
Nothing really explains "why" in physics. "Why" questions necessarily appeal to a lower level, more fundamental layer of science. If you are talking about the lowest level or more fundamental science then any question of "why" becomes irrelevant and you really should be asking "what".
