Which Celestial Body in the Solar System Allows a Probe to Orbit Fastest?
The discussion centers on calculating the fastest orbital period of a probe around celestial bodies in the solar system with diameters greater than 1000 km. Tethys, with a diameter of 1060 km, is suggested as a potential candidate for the fastest orbit due to its smaller size. The orbital period can be calculated using the formula: 2 * π * (radius of celestial body) / orbital velocity. Key insights include the importance of gravitational force and centripetal force in determining orbital velocity, emphasizing that smaller celestial bodies may offer shorter orbital periods despite their lower mass.
  • Understanding of gravitational force and centripetal force
  • Familiarity with basic orbital mechanics
  • Knowledge of the formula for orbital period
  • Concept of density and volume of celestial bodies
  • Research the gravitational force equations for celestial bodies
  • Learn about the relationship between orbital velocity and mass of celestial bodies
  • Explore the concept of orbital mechanics in detail
  • Investigate the properties of Tethys and other celestial bodies in the solar system
Astronomy students, astrophysicists, and anyone interested in orbital mechanics and the dynamics of celestial bodies in the solar system.
Numeriprimi
Hello.
In my book with examples of astronomy, I found this: Calculate, around which the known celestial bodies in the solar system (with a diameter greater than 1000 km) do a probe one complete cycle fastest (without the use of engines). Other movements of these bodies is negligible.
If cycle must be fast, it must be a celestial body with small diameter (but greater than 1000 km). It is Tethys (1060 km) or something smaller?
It is true that the circulation period is equal to:
2 * π * (radius of celestial body + height probe above the surface) / speed the probe
It is good?
Sorry for my bad English.
Astronomy news on Phys.org
This would probably fit better in the homework section, even though it's not exactly homework. You might try asking this kind of questions there in the future.
I assume you mean to calculate orbital velocity at minimal height - that is, as if the satellite were orbiting just above the surface, with no atmospheric drag, or mountains to worry about.
You want minimal height, because that's where the orbit is the fastest.
You want to find out how the orbital period changes with radius of the planet the probe is orbiting.
The equation for the period you've provided is indeed good, but you can drop the "height above surface" part, since we're trying to imagine it going around the planet/moon at zero height.
You still need to find out what is the speed, as it will not be the same for all bodies.
To do so, look up the force of gravity, and the centripetal force, and write an equation that compares them:
FG=Fc
solve for velocity.
The important bit is to express mass of the central body in terms of volume of a sphere and density.
Plug in the velocity to the equation for the period, and tell us what do you think it now tells you about the relationship between the radius and the period.
Smaller objects have a smaller circumference, but they also have a lower mass.
There is a nice relation between the time for an orbit and one specific, single parameter of the object. This allows to find the "best" one in our solar system.
  • · Replies 86 ·
9K
  • · Replies 21 ·
  • · Replies 1K ·
36
192K
