Calculate the circulation of vector field
The discussion focuses on calculating the circulation of the vector field \(\vec{v} = \cos(x)\sin(y)\vec{i} - \sin(x)\cos(y)\vec{j}\) around a square defined by the bounds \(-\frac{\pi}{2} \leq x \leq \frac{\pi}{2}\) and \(-\frac{\pi}{2} \leq y \leq \frac{\pi}{2}\). The user, Marius, correctly identifies that the circulation along one side can be multiplied by 4 to obtain the total circulation, resulting in a final value of \(I = 8\). The discussion also confirms the result using Stokes' theorem, where the curl of the vector field is calculated as \(\vec{\nabla} \times \vec{v} = -2\cos(x)\cos(y)\hat{z}\).
  • Understanding of vector fields and line integrals
  • Familiarity with Stokes' theorem
  • Knowledge of calculus, specifically integration techniques
  • Ability to compute the curl of a vector field
  • Study the application of Stokes' theorem in various contexts
  • Learn about vector field visualization tools for better understanding
  • Explore advanced integration techniques in multivariable calculus
  • Investigate the properties of line integrals in different coordinate systems
Mathematicians, physics students, and engineers interested in vector calculus, particularly those working with line integrals and fluid dynamics.
Jonsson
Hello there,
I've got a vector field which you can see here: Sketch of the vector field . It is: [itex]\vec{v} = \cos(x)\,\sin(y)\vec{i}-\sin(x)\,\cos(y)\vec{j}[/itex]
Say I want to find the circulation around the square formed by [itex]-\frac{\pi}{2} \, \leq x \leq \, \frac{\pi}{2}[/itex] and [itex]-\frac{\pi}{2} \, \leq y \leq \, \frac{\pi}{2}[/itex]. I think that I should do this by finding the circulation along one of the sides, and multiply by 4 (I can tell from the vector field that the circulation along one of the sides is going to be equal to every other side.
This is where I become unconfident. [itex]\int_{y = -\frac{\pi}{2}}^{y = \frac{\pi}{2}}\vec{v}\,\mathrm{d}\vec{r}[/itex] Please correct me if I am wrong. Any criticism is appreciated:
My [itex]\mathrm{d}\vec{r} = \mathrm{d}y\vec{j}[/itex] along the y-axis, for the first side: [itex](\Delta y = -\frac{\pi}{2}, x = -\frac{\pi}{2})[/itex].
[itex]\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}} \cos(x)\,\sin(y) \, \mathrm{d}y -\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\sin(x)\,\cos(y) \, \mathrm{d}y[/itex]
[itex]\cos(-\frac{\pi}{2}) = 0[/itex], so the first integral is equal to zero.
[itex]-\sin(-\frac{\pi}{2})\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\cos(y) \, \mathrm{d}y = \int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\cos(y) \, \mathrm{d}y = [\sin(y)]_{-\frac{\pi}{2}}^{\frac{\pi}{2}} = \sin(\frac{\pi}{2}) - \sin(-\frac{\pi}{2}) = 2[/itex]
First question:
Is the above correct?
Second question:
Can you think of any additional criticism?
Thank you for your time.
Kind regards,
Marius
You are correct if you multiply your result by 4 to get the value of the line integral ##I=8##.
You can check the result using Stokes' theorem $$\oint \vec{v}\cdot d\vec l=\int_S \vec {\nabla}\times \vec v \cdot \hat n~dS$$Here, ##\vec {\nabla}\times \vec v=-2\cos(x)\cos(y)~\hat z##. We have already chosen clockwise line integration therefore ##\hat n=-\hat z##.Thus, $$\int_S \vec {\nabla}\times \vec v \cdot \hat n~dS=+2\int_S\cos(x)\cos(y)dx~dy=2\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\cos(x)dx\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\cos(y)dy=8.$$
  • · Replies 17 ·
