How do you compute the circulation of this fluid (path integrals)
The discussion focuses on calculating the circulation of a fluid with the velocity field F(x, y, z) = (xy, yz, xz) along the unit circle C in the xy-plane. The initial assumption that the line integral ∫ F * dr equals zero is challenged when it is determined that F is not conservative, as indicated by the failure to satisfy the condition F = ∇f. Participants suggest using a parametrization of the unit circle, specifically r(t) = (cos(t), sin(t), 0), to compute the integral directly and clarify the nature of the circulation.
  • Understanding of vector fields and circulation
  • Knowledge of line integrals in vector calculus
  • Familiarity with conservative fields and the gradient operator (∇)
  • Ability to parametrize curves in three-dimensional space
  • Learn how to compute line integrals of vector fields using parametrization
  • Study the properties of conservative vector fields and their implications on circulation
  • Explore the concept of path independence in vector calculus
  • Investigate the application of Green's Theorem in calculating circulation in the plane
Students and professionals in mathematics, physics, and engineering who are working with fluid dynamics, vector calculus, or line integrals.
randomcat
A fluid as velocity field F(x, y, z) = (xy, yz, xz). Let C denote the unit circle in the xy-plane. Compute the circulation, and interpret your answer.
Since the unit circle is a closed loop, I assumed that ∫ F * dr = 0
(the ∫ symbol is supposed to have a circle)
However, when I attempt to verify whether or not F = [itex]\nabla[/itex] f, the two are not equal, suggesting that ∫ F * dr does not= 0
At this point I'm at a loss of how to go about calculating the circulation. Could someone please help?
You just want to calculate the integral. Pick a parametrization of the unit circle, like r(t)=(cos(t),sin(t),0) and work it out.
I would rephrase this to "suggesting that ∫ F * dr might not= 0" Note that IF the vector field is conservative then every closed path integral must be zero; however, the opposite is not necessarily true. There are many cases when the field is not conservative but a given closed path integral is still zero (and I suspect that this problem will end up being one of those cases).
Good Luck!
