Interpreting Matlab function simp
  • Context: MATLAB
  • Thread starter Thread starter Ein Krieger
    Function Matlab
The discussion revolves around the interpretation and usage of a custom MATLAB function named `simp`, which is related to numerical integration using Simpson's rule. Participants are exploring how to apply this function to integrate a specific array of values over a defined interval, while clarifying the parameters involved in the function.
  • One participant seeks clarification on whether the variable `I1` represents an integration of 21 slices between the boundaries 0 and `r0`.
  • Another participant requests more context and details about the variables used in the provided code snippet.
  • A participant points out that `simp()` is not a standard MATLAB function and suggests checking the function file for input arguments.
  • Information about the `simp` function is shared, detailing its parameters: a function `f`, initial value `a`, end value `b`, and interval size `h`.
  • A participant shares a separate implementation of the `simp` function, raising a question about the use of different variable names (`xl` and `xu`) compared to the original query.
  • Clarifications are made regarding the meaning of the variables `xl`, `xu`, `n`, and `u`, suggesting that `u1d` is integrated from 0 to `r0` using `nr` intervals.
  • There is a question about whether the `simp` function can be applied uniformly to different types of variables, provided the order of arguments is correct.
Participants express uncertainty regarding the specific definitions and roles of variables in the `simp` function, and there is no consensus on the implications of using different variable names. The discussion remains unresolved with multiple interpretations of the function's application.
Limitations include the lack of clarity on the definitions of certain variables and the absence of a complete understanding of the `simp` function's implementation as it is not a standard MATLAB function.
Ein Krieger
Hello, guys
Hey guys,
Got stuck with function integration using Simpson's rule and need your help.
Please first refer to picture attached for full idea of my question:
The Matlab command related to it is:
for i=1:nr
u1d(i)=4.0*pi*r(i)^2*u(it,i)
end
I1=simp(0.0,r0,nr,u1d)/(4.0/3.0*pi*r0^3)
I1 is
nr=21
r0=1.0;
Does it mean that I1 is integrated 21 times between boundaries 0 and r0?
Can you post more information? The code you posted references variables that you never define. Make it so that your code block can be copy/pasted into matlab.
Yes. Sure
I have attached all commands with order from Pic.1 to Pic.3
simp() is not a MATLAB function, so the information about the input arguments is not available in the documentation. I suggest looking at the function file for simp() to find this info.
EDIT: I found information about this function in the MATLAB file exchange.
Code:
function s = simp(f, a, b, h)
x1 = a + 2 * h : 2 * h : b - 2 * h;
sum1 = sum(feval(f, x1));
x2 = a + h : 2 * h : b - h;
sum2 = sum(feval(f, x2));
s = h / 3 * (feval(f, a) + feval(f, b) + ...
           2 * sum1 + 4 * sum2);
It appears that the inputs are:
f=function, a=initial value, b=end value, h=interval size
I have found it as separate m.file. Here are the commands:
function uint=simp(xl,xu,n,u)
h=(xu-xl)/(n-1);
uint(1)=u(1)-u(n);
for i=3:2:n
uint(1)=uint(1)+4.0*u(i-1)+2.0*u(i);
end
uint=h/3.0*uint;
But why here different variables are used such as xl and xu?
It seems to me that we use r in integration?
At a glance it looks like
xl = beginning of interval
xu = end of interval
n = number of slices
u = function
So in your case of
Code:
You are integrating u1d from 0 to r0 with nr intervals
u = function
So in your case of
Code:
So you mean simp can be uniformly used for every type of variable assuming their correct order?
18K
