Friction with a Magnetic Bearing System?
The discussion revolves around the behavior of a magnetic bearing system in a motor context, specifically focusing on energy transfer, the effects of magnetic interactions, and the implications of using magnets to slow down a rotating shaft. Participants explore theoretical scenarios and practical considerations regarding friction, energy loss, and the nature of magnetic forces.
  • One participant questions where mechanical energy goes when a motor with magnetic bearings is slowed down by another magnet, pondering the role of magnetic friction and energy destruction.
  • Another participant clarifies that slowing down implies a load, suggesting that the interaction between magnets would inherently involve energy transfer.
  • A different participant explains that magnets do not work by friction, proposing that in a perfect system, the motor would oscillate without energy loss, but acknowledges real-world energy losses due to air resistance and material flexing.
  • One participant introduces the idea that a magnet could induce eddy currents, which would convert energy into heat, thus contributing to energy loss in the system.
  • Another participant describes a scenario where the motor transfers energy to a magnetic rotating shaft and questions whether the attraction of magnets would slow the shaft to a stop.
  • A participant emphasizes that energy is never destroyed but eventually dissipates as heat, comparing the system to a fridge magnet and discussing the implications of running the bearing in a vacuum to eliminate air resistance.
  • One participant expresses uncertainty about the mechanics of the magnetic bearing system and its potential effectiveness, particularly in relation to the attraction of magnets slowing down the shaft.
Participants express various viewpoints on the mechanics of magnetic interactions and energy transfer, with no consensus reached on the overall effectiveness or implications of the proposed magnetic bearing system. Multiple competing views remain regarding the nature of energy loss and the role of magnetic forces.
Participants acknowledge limitations in their understanding of the system, including assumptions about ideal conditions, the effects of real-world losses, and the complexities of magnetic interactions. The discussion remains open-ended with unresolved questions about the practical application of the concepts discussed.
Thesnake22
One question that I have been thinking about for a while is if you were to use magnetic bearings (no physical friction) for a type of motor and put energy into it by spinning it and slow it down with another magnet, where does the mechanical energy go? If there is no physical contact with the bearing will it produce heat because of the magnetic friction? or Will the energy be completely destroyed?
What do you mean by "slow it down with another magnet" ?
"Slow" implies a load of some sort and that's your answer.
"By slowing it down with another magnet," I mean that the magnet is used as a form of friction and prevents the motor for rotating after the work is applied to it.
Magnets don't work by friction. Instead like poles repel each other. If you don't have enough momentum or velocity to overcome this repulsion the motor would simply come to a stop and then be accelerated the other way before coming to a stop again as it approached the magnet once more. In a perfect system with no losses it would simply oscillate back and forth.
If instead you had enough velocity to overcome the repulsion, the motor would slow down as one of its poles approached the magnet and then accelerate back up to speed once it passed the magnet. No energy loss.
However, we don't have perfect systems in real life. You will lose energy through friction with the air and with the flexing of the magnet and motor.
I suppose a magnet could slow the motor by causing eddy currents. Bit like a dynamo with the output shorted. In which case the energy would go into heating the motor.
I'm sorry, I forgot to mention that the motor is attached to another system (which is a magnetic rotating shaft). You first transfer the energy from the motor to the rotoring shaft then disconnect the motor, so that the shaft is running off momentum. Then have the magnets attract one another. Should the attraction of the magnets slow the staft to a stop?
Anybody?
Energy is never destroyed, but eventually it all ends up as heat as we all know. I believe (and am not sure) that since there is actually 'work' being done that eventually there is energy being spent. Compare for instance a fridge magnet stuck to a door: not doing any 'work', so it will probably hang there forever and not lose it's magnetism, as opposed to your magnetic bearing system where there is continuous motion, resulting in energy being spent. Although there is extremely little friction, there will be energy release in very small quantities over a long period, since the magnet won't lose it's energy quickly (especially if its a rare-earth magnet with very high coercivity). Another consideration: What if you run this bearing in a vacuum, where even the air resistance is removed? I myself have been working on such a concept involving a polar array setup of permanent neo magnets to use as a magnetic bearing - not even sure if it would work!
...so that the shaft is running off momentum. Then have the magnets attract one another. Should the attraction of the magnets slow the staft to a stop?
You haven't really explained what you mean by "have the magnets attract one another" but the answer is probably yes.
You certainly can't make a permanent magnet motor so just about any arrangement of permanent magnets you add to a spinning shaft will slow it down faster than if they weren't there.
