What is the maximum rate of angle change for a function?
  • Context: Graduate
  • Thread starter Thread starter Gackhammer
    Angle Change Rate
The maximum rate of angle change for a function can be determined using the derivative of the arctangent of the first derivative, represented as (arctan(y'))'. This derivative simplifies to \(\frac{y'}{(y')^2 + 1}\). To find the greatest rate of angle change, set the derivative of this expression to zero, leading to the equation \(y''' - 2(y')^2y' + y'''(y')^2 = 0\). This discussion explores the implications of this differential equation and its solutions.
  • Understanding of calculus, specifically derivatives and their applications
  • Familiarity with the arctangent function and its properties
  • Knowledge of differential equations and their solutions
  • Experience with function analysis and critical points
  • Research methods for solving higher-order differential equations
  • Learn about the applications of arctan in calculus
  • Explore optimization techniques for functions and their derivatives
  • Study the implications of critical points in function behavior
Mathematicians, calculus students, and anyone interested in advanced function analysis and optimization techniques.
Gackhammer
So I have been thinking of this problem... what is the greatest rate of angle change for a function? As in, what is the point in which a function achieves its greatest rate of angle change...
Well, the angle of a function can be determined by arctan(y')
The Rate of Angle change is (arctan(y'))', which equals [itex]\frac{y'}{(y')^2 +1}[/itex]
So the greatest rate of angle change is the derivative of that set to zero, which is equal to
[itex]\frac{y''' - 2(y')^2y' + y'''(y')^2}{((y')^2 +1)} = 0[/itex]
Which , you can simplify to...
[itex]y''' - 2(y')^2y' + y'''(y')^2= 0[/itex]
Is there a way that this differential equation can be solved? (This is not for homework, this is just a general question that I would like to know the answer to)
So the greatest rate of angle change is the derivative of that set to zero...
Or you could use the fact that ##\frac{x}{x^2+1}## attains it's maximum at x=1.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 18 ·
