Microwave photons, when do they become real?
  • Context: Graduate
  • Thread starter Thread starter Spinnor
    Microwave Photons
The discussion revolves around the nature of microwave photons produced by a magnetron in a microwave oven, specifically questioning when these photons can be considered "real" versus "virtual." Participants explore concepts related to electromagnetic radiation, virtual photons, and the implications of group velocity in this context.
  • Some participants question whether the electromagnetic energy traveling in the waveguide can be considered virtual photons until it leaves the waveguide, while others argue that photons are real once produced in the magnetron.
  • One participant asserts that virtual photons do not heat food or transmit signals, suggesting that real photons are necessary for these processes.
  • Another participant challenges the idea that group velocity defines the reality of photons, emphasizing the need for a clear understanding of what virtual photons are.
  • A participant suggests that discussions about virtual photons often lack mathematical rigor, indicating that such discussions may be oversimplified.
  • Some participants note that virtual photons are more of a mathematical construct rather than real particles, pointing out the absence of detectors for virtual photons.
  • One participant mentions the near field and far field phenomena related to microwave ovens, suggesting that virtual photons may be included in the near field context.
  • Another participant draws a parallel between the microwave oven and particle accelerators, questioning if microwaves can accelerate electrons similarly.
  • Several participants express frustration over repeated questions regarding the distinction between real and virtual photons, indicating a lack of consensus on the topic.
Participants do not reach a consensus on whether microwaves are real photons once produced in the magnetron or if they are virtual until they exit the waveguide. Multiple competing views remain, with some participants asserting the reality of photons at different stages and others emphasizing the distinction between real and virtual photons.
Participants express uncertainty regarding definitions and the implications of group velocity on the classification of photons. The discussion reflects a range of interpretations and assumptions about the nature of virtual and real photons without resolving these complexities.
Spinnor
A microwave oven produces microwaves that can heat food.
Can we consider the electromagnetic energy leaving the magnetron and traveling in the waveguide virtual photons and when the electromagnetic energy leaves the waveguide the electromagnetic energy "becomes" real photons? Or are they "real" once produced in the magnetron?
Thanks for any help!
Science news on Phys.org
Virtual photons do not heat food or transmit signals.
Zz.
Zz.
Real photons travel at c, energy in the wave guide travels slower then c, --> not real?
Since when does the group velocity of light defines if it is real or virtual? Do you even know what is a virtual photon?
Zz.
Zz.
Can you give me a multiple choice test?
There's no really good answer because we're using English to kinda vaguely talk our way around a concept that is most clearly expressed in the language of mathematics. So don't be too disappointed if no one comes up with a really clear answer.
But with that said, I'll give it a try. Wherever there is electromagnetic radiation, there are photons - real photons, not virtual ones. When one person says "the magnetron produces photons" and another person says "the magnetron produces waves", that's just two different ways of saying the same thing.
One pretty good rule of thumb though: Any time you find yourself reading about virtual photons... If you don't also see a page full of equations, you're reading something that is oversimplified enough that you should think of it as a metaphor or an analogy, not a serious explanation of the way things really are.
Just to add to Nugatory's overall great post is that virtual photons are more like a math artifact to better suite our understanding of the world and the forces in it than a real particle.
If it would be real there would be separate detectors for virtual photons but there are no such things.You only detect real photons.
Even though as with any transmitter the microwave oven does have a far field and near field phenomenon I suppose.So @ Nugatory the magnetron produces photons one says, yes, other says it produces Em waves again yes but back to the first picture it does also produce virtual photons as they constitute a part of the near field.So there is electromagnetic radiation but according to what I just checked virtual photons included.
But then again are they in the near field because of the way we do our math or because they really are there , the answer would be the math.
I recall a thread here on PF in which i too took part that discussed these things.
The microwaves are real once they are produced by the magnetron.
From, "How Atom Smashers Work"
http://science.howstuffworks.com/atom-smasher4.htm
"The major structure of the particle accelerator is the copper tube. The copper tube has a strong vacuum inside through which the particles travel. The tubes are made of copper because copper conducts electricity and magnetism very well. At the SLAC linac, the copper tube is made of more than 80,000 copper cylinders brazed together for more than 2 miles (3.2 km)!
The copper tube is arranged to form a series of cells called cavities. The spacing of the cavities is matched to the wavelength of the microwaves. The spacing allows the electric and magnetic fields to repeat their pattern every three cavities. Electrons or positrons in the beam come through the cavities in small bunches. The arrival of each bunch is timed so that it gets a push from the electric field across the cavities. "
Ignoring any mistakes above, if I substituted the above system for the microwave oven in the top post are the microwaves accelerating the electrons just as real?
See diagram below.
Thanks for your help!
This is getting seriously off topic. You were told in many different ways of what is real and what is virtual. Somehow, you are refusing to accept them and continue to ask the same thing.
Zz.
Zz.
How do you rate the accuracy of the wiki article on virtual photons?
http://en.wikipedia.org/wiki/Virtual_particle
The same way I would rate this thread... Done!
Zz.
  • · Replies 59 ·
12K
