Solving a Momentum Question: Struggling with Simple Cons?
  • Context: Graduate
  • Thread starter Thread starter stallm
    Momentum
The discussion focuses on a momentum problem involving a particle of rest mass 2m moving with velocity v in frame S, where its momentum is defined as p=2mv/√(1-v²). Upon splitting into two particles of mass m with velocities v and -v in the rest frame S', the participant encounters discrepancies in momentum and energy conservation. The velocity addition formula is applied, yielding a new velocity v_new=2v/(1+v²), but the resulting momentum does not match the initial momentum, indicating a violation of energy conservation. The participant concludes that the total energy after the split exceeds the initial energy, highlighting a critical misunderstanding in relativistic momentum and energy conservation.
  • Understanding of relativistic momentum and energy conservation principles.
  • Familiarity with the velocity addition formula in special relativity.
  • Knowledge of the concept of rest mass and its implications in relativistic physics.
  • Basic proficiency in algebra and manipulation of equations.
  • Study the implications of relativistic mass versus rest mass in particle physics.
  • Learn about energy-momentum four-vectors and their applications in special relativity.
  • Explore detailed examples of particle collisions and decays in relativistic contexts.
  • Investigate the conservation laws in different inertial frames and their significance in high-energy physics.
Students and professionals in physics, particularly those focusing on special relativity, particle physics, and energy conservation principles. This discussion is beneficial for anyone seeking to deepen their understanding of relativistic mechanics and its applications.
stallm
Hi, I've been struggling with this question for a while, can't help but think I'm missing something obvious
Let's say I have a particle of rest mass 2m. In the frame S, it moves with velocity v. S' is the rest frame of the particle. In S, the momentum of the particle (c=1)
[itex]p=\frac{2mv}{\sqrt{1-v^2}}[/itex]
Now, in S', the particle splits into two particles of mass m with velocities v and -v. The particles with -v will be stationary in S, the particle with v will have velocity vnew
[itex]v_{new}=\frac{v+v}{1+v^2}=\frac{2v}{1+v^2}[/itex]
by the velocity addition formula
So the momentum in S
[itex]p=\frac{mv_{new}}{\sqrt{1-v_{new}^2}}[/itex]
This doesn't appear to be equal to the p before (just by trying v=0.5), so something's clearly gone wrong. Can someone help?
Thanks
This step does not conserve energy. In S' before the split the total energy was 2m. But after the split each particle will have energy greater than m, since it has rest energy m plus kinetic energy.
Ah I see. Thank you
  • · Replies 50 ·
  • · Replies 55 ·
  • · Replies 24 ·
  • · Replies 19 ·
