Mathematica to FindFit for multiple data set
The discussion centers on using Mathematica to fit multiple data sets simultaneously with the function y=ax+b, where each data set has unique parameters a and b. The solution provided involves utilizing the Map function in Mathematica to apply FindFit across a collection of data sets. The specific implementation shared is: Map[FindFit[#, a x + b, {a, b}, x] &, {data1, data2, data3}]. This approach effectively streamlines the fitting process for multiple data sets.
  • Familiarity with Mathematica programming language
  • Understanding of the FindFit function in Mathematica
  • Basic knowledge of linear regression concepts
  • Experience with data manipulation in Mathematica
  • Explore advanced features of the FindFit function in Mathematica
  • Learn about the Map function and its applications in Mathematica
  • Investigate techniques for optimizing data fitting processes
  • Study examples of fitting multiple datasets in Mathematica
Data scientists, researchers, and analysts who need to perform simultaneous data fitting in Mathematica, particularly those working with multiple datasets requiring linear regression analysis.
Sue Laplace
After conducting my experimental work I will have a number of sets of data.
It is easy to use Mathematica to find a fit of just one set, but I would like to fit all sets at once as they are too many to do them all ate once.
They will all be fitted by the same function say y=ax+b, every set having a different value of a and b.
How do I do this?
Thanks in advance.
Sue
Without a concrete specific example it is perhaps difficult to know exactly what the answer should be.
Usually if you want to "do the same thing to a collection of items" Map[] is the solution.
data1={...};
data2={...};
data3={...};
Map[FindFit[#,a x+b,{a,b},x]&,{data1,data2,data3}]
may do what you want.
http://reference.wolfram.com/mathematica/ref/Map.html
Thank you very much Bill, it is working.
9K
