Triple Integration of charge density question
The discussion revolves around calculating the total charge of two different geometrical shapes: a square capacitor plate and a sphere, using specified charge density functions. The charge density for the capacitor plate is given as f(x,y,z) = 1+x+y, while for the sphere it is f(x,y,z) = x+y+z. The participants are exploring the application of triple integration as per Gauss' theorem to find the total charge.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the integration process for both shapes, with some attempting to set up the integrals while others question the limits of integration and the appropriateness of the charge density functions. There is also a suggestion to convert to spherical coordinates for the sphere to simplify the integration.
There is ongoing exploration of the integration methods and the implications of the limits chosen for the integrals. Some participants have provided guidance on correcting integration limits and the importance of the charge density function's behavior. The discussion reflects a mix of attempts and clarifications without reaching a definitive conclusion.
Participants note the importance of specifying limits for the integrals based on the geometry of the shapes involved. There is also a discussion about the arbitrary nature of the charge density function and its implications for the physical interpretation of the problem.
CraigH
a)Calculate the total charge a square capacitor plate would have with width x, height y, thickness z, and charge density f(x,y,z) = 1+x+y
b)Calculate the total charge a sphere would have with radius r, and charge density f(x,y,z)=x+y+z
Use the triple integration seen in gauss' theorem and show all working.
[itex]Q= \int\int\int\rho .dv[/itex]
[itex]\rho = Charge Density[/itex]
[itex]v=Volume[/itex]
a)
[itex]\int\int\int f(x,y,z) .dv[/itex]
[itex]\int\int\int f(x,y,z) .dx.dy.dz[/itex]
[itex]\int\int\int 1+x+y .dx.dy.dz[/itex]
[itex]\int\int x + x^2 + yx .dy.dz[/itex]
[itex]\int xy + (x^2)y + x(y^2) .dz[/itex]
[itex]Charge = xyz +(x^2)yz + x(y^2)z[/itex]
//I think this one is correct?
b)
[itex]\int\int\int x+y+z .dx.dy.dz[/itex]
//I get stuck here with this one because it is a sphere and not just a simple shape
By the way the charge density function is completely arbitrary. I understand that charge would not spread itself out inside a capacitor plate like
charge density = f(x,y,z) = 1+x+y
A sphere is a pretty simple shape.
For calculating the charge on the sphere, I would suggest you convert to spherical coordinates before integrating.
a)
No, you have a slight mistake. You integrated the "x" to "1*x2". You made the same kind of mistake when integrating y. What is it supposed to be?
Also, you didn't include any limits on the integral, which could be important. You tell us that the plate has dimensions X by Y by Z (I'm using uppercase to distinguish from the coordinates x, y and z), but you don't tell us if the coordinates run from x = 0 to X, y = 0 to Y, z = 0 to Z or x = -X/2 to +X/2, y = -Y/2 to +Y/2, etc. It matters which it is, because your density is 1 + x + y, and can have negative charge on the conductor in the second set of limits I mentioned.
Thank you for answering. Ah yes the integral should be
Charge = (x)(y)(z) + 0.5(x^2)(y)(z) + 0.5(y^2)(x)(z)
And I can see now how the limits would be important. If (0,0,0) is the close bottom left of the plate, and (X,Y,Z) is the far top right of the plate these would be the limits. I can see that I also could have chose (0,0,0) as the centre of the plate.
So if I substitute in the limits after each integration I get:
[itex]\int^{X}_{0}\int^{Y}_{0}\int^{Z}_{0} 1+x+y .dx.dy.dz[/itex]
[itex]\int^{X}_{0}\int^{Y}_{0} [x + 0.5x^2 + yx]^{Z}_{0} .dy.dz[/itex]
[itex]\int^{X}_{0}\int^{Y}_{0} (Z + 0.5Z^2 + yZ)-(0 + 0.5(0)^2 + y(0)) .dy.dz[/itex] //The lower limit will always be zero so I won't include it from now
[itex]\int^{X}_{0}[Zy + 0.5(Z^2)y + 0.5(y^2)Z]^{Y}_{0} .dz[/itex]
[itex]\int^{X}_{0}(ZY + 0.5(Z^2)Y + 0.5(Y^2)Z) .dz[/itex]
[itex]Charge = [ZYz + 0.5(Z^2)Yz + 0.5(Y^2)Zz]^{Y}_{0}[/itex]
[itex]Charge = (ZYY + 0.5(Z^2)YY + 0.5(Y^2)ZY)[/itex]
[itex]Charge = (ZY^2 + 0.5(Z^2)Y^2 + 0.5(Y^3)Z)[/itex]
This doesn't seem correct, the width of the plate (denoted by X) apparently doesn't affect the charge when it obviously should. Have I made another careless mistake or am I doing something wrong in the method?
Okay, I see what I did wrong, the limits are in the wrong order. The upper limits should be Z, Y, X, from left to right. If I didn't do this though did I do the rest of the method correctly?
Thanks. I have attempted part b with the spherical coordinate system and it is much easier to understand. I'm just now waiting to check that I am doing the triple integrations with limits the correct way.
It looks like your integrations are fine, you're just mixing up the limits, which seems to have caused you to get confused and lose your X somewhere. You're correct that all of X, Y and Z should appear in your solution. The order of integration doesn't matter, but you want to make sure that when you integrate with respect to x the upper limit should be x.
Thank you for helping, it is very much appreciated! I will definitely repay what I owe to this sites users once I have finished exams by answering other peoples questions, as this site has helped me quite a lot.
One more quick question though before I'm completely confident with this topic:
Can you always replace .dv with .dx.dy.dz?
like I did here
∫∫∫f(x,y,z).dv
∫∫∫f(x,y,z).dx.dy.dz
Or is this only for a cuboid shape?
If not, what would it be for other simple shapes?
Yes. dxdydz is the volume element in Cartesian coordinates. Even a sphere can be notionally thought of as composed of such elements because, in the limit as the elements tend to zero, the edge error tends to zero. When it is not a rectangular box, the awkward part is the ranges. The range of an inner integral will depend on the local value of a coordinate in an outer integral.
Other coordinate systems, spherical, cylindrical, ..., have other forms for the volume element. When converting from one to another you generally need to introduce a factor known as the Jacobian. E.g. the area element in polar is rdrdθ, the factor r being the Jacobian.
