How to Solve This Coupled PDE System Involving Complex Variables?
The discussion focuses on solving a coupled partial differential equation (PDE) system involving complex variables, specifically the equations (r^2 ∇² - 1) X(r,θ,z) + 2 ∂Y/∂θ = 0 and (r^2 ∇² - 1) Y(r,θ,z) - 2 ∂X/∂θ = 0. A proposed solution involves defining Z(r,θ,z) as X(r,θ,z) + i Y(r,θ,z), which simplifies the problem. The user suggests that separation of variables may not work due to the coupling, but using the substitution z = x + iy allows for the reduction of the system to a single equation. The final equation presented is (r^2 ∇² - 1) Z(r,θ,z) - 2i ∂Z/∂θ = 0.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with complex variables and functions
  • Knowledge of separation of variables technique
  • Experience with Fourier transforms
  • Research the method of separation of variables in PDEs
  • Learn about Fourier transforms in the context of complex variables
  • Explore techniques for solving coupled PDE systems
  • Investigate the implications of real and imaginary parts in complex equations
Mathematicians, physicists, and engineers dealing with complex variable PDEs, as well as students and researchers looking to deepen their understanding of coupled systems in mathematical physics.
DukeLuke
[tex] (r^2 \nabla^2 - 1) X(r,\theta,z) + 2 \frac{\partial}{\partial \theta} Y(r,\theta,z) = 0[/tex]
[tex] (r^2 \nabla^2 - 1) Y(r,\theta,z) - 2 \frac{\partial}{\partial \theta} X(r,\theta,z) = 0[/tex]
any suggestions are greatly appreciated :)
I would start with defining
[tex]Z(r,\theta,z) \equiv X(r,\theta,z) + i Y(r,\theta,z)[/tex]
Then you have less work to do. It looks like separation of variables might be successful, have you tried that? Or a Fourier transform would certainly work.
I tried separation of variables, but it didn't work because of the coupling. Using z=x+iy I was able to reduce the system to a single equation (multiply the 2nd equation by i and add it to the first).
[tex] (r^2\nabla^2-1)Z(r,\theta,z) - 2i \frac{\partial Z(r,\theta,z)}{\partial \theta} = 0[/tex]
Is it necessary that the real and complex parts individually equal 0? I was thinking of trying separation of variables for this equation in Z, but I'm unsure how to deal with the complex portion.
  • · Replies 36 ·
