How Long Does It Take for CO2 to Diffuse in a Nitrogen-Filled Vessel?
The discussion centers on the diffusion of CO2 in a nitrogen-filled vessel, specifically a bundle of 17 x 50-liter cylinders filled to a final pressure of 200 bar. The initial CO2 concentration is 30%, but analysis often shows only 24-26% immediately after filling, improving to around 30% after 4 hours. The slower diffusion rate of CO2 compared to nitrogen, with a diffusion rate of 1.25, is identified as a contributing factor. Proposed solutions include using smaller vessels for quicker analysis, increasing pump speed to raise temperature, and pre-heating CO2 before introduction into the vessel.
  • Understanding of gas diffusion principles
  • Knowledge of gas mixture properties and behavior under pressure
  • Familiarity with pressure and temperature effects on gas states
  • Experience with gas filling processes and equipment
  • Research the diffusion coefficients of CO2 and nitrogen under varying pressures and temperatures
  • Learn about the critical properties of gases, specifically CO2, including critical pressure and temperature
  • Investigate methods for rapid gas analysis in industrial applications
  • Explore techniques for optimizing gas filling processes to enhance diffusion rates
Professionals in gas handling and filling operations, chemical engineers, and anyone involved in optimizing gas mixtures and diffusion processes in industrial settings.
rad10k
Ok so I wish to try solve a problem at work I will try explain as best I can .
Problem Definition;
Filling of a bundle of cylinders 17 x 50litre ( 850 000 k/m^3). 30 % Co2 in the cyindrical vessal followed by input of Nitrogen 70% to a final pressure of 200 bar
Due to production requirements it is often required to analysis the gas straight away after filling and more often than not the analysis for CO2 is reaching only 24 - 26 % which is under spec
If the vessals were left for instance 4 hours then upon anaylsis a reading of around 30% CO2 would be found.
My thoughts are with the diffusion of the CO2 in nitrogen as CO2 rate of diffusion is 1.25 to n2 is this causing the CO2 to take time to uniformly distribute throughout the vessal.
I would like to know how to calculate the time it will take for the CO2 to diffuse in the vessal given the final pressure and temperature of the vessal? if possible
Solution:
My current thought on solutions;
1. Fill a much smaller vessal as well at the same time and use that for analysis since the cylinder will get hotter causing the gases to diffuse quicker.
2. Increase pump speed to increase the temperature of the 17x50 bundle which in turn will increase the rate of diffusion.
3. heat the CO2 liquid before it enters the vessal increase the rate of its diffusion once inside the vessal
Any help and advice ie am I on the right track please
thanks
Chemistry news on Phys.org
I wonder how you're filling these bundles. Are they being weighed and a specific amount of CO2 added or are they filled to a specific pressure? Once filled to that limit, I assume you're adding the nitrogen.
The critical pressure and temperature of CO2 is 1071 psia and 87.9 F respectively. It's very possible the partial pressure and temperate of CO2 is below that, in which case there can be liquid CO2 in equilibrium with the gas. So if you can better define the gas mixture, it would help.
Hi they are filled to pressure and temp. Liquid is cooled then vapourised. Co2 goes in first as you say then n2 upto specific pressure and temp to reach thre required final pressure (190 b)
  • · Replies 41 ·
  • · Replies 19 ·
11K
9K
  • · Replies 18 ·
13K
  • · Replies 47 ·
9K
