Find Velocity: Help on Part B | 19.6 J, 5.0 kg, 2.8 m/s
  • Thread starter Thread starter KTiaam
    Velocity
The discussion revolves around calculating the velocity of a mass at a specific time, given its initial velocity and the work done on it. The subject area includes concepts from mechanics, specifically relating to motion and forces.
  • Mixed
  • Participants explore the relationship between force, mass, and acceleration, questioning how to derive acceleration from given work and distance. There are attempts to apply kinematic equations, but some participants express uncertainty about the necessary formulas.
Some participants have provided insights into calculating acceleration and have shared their findings, while others are still working through the implications of the equations involved. There is a mix of interpretations regarding the application of formulas, but no explicit consensus has been reached.
Participants note the importance of initial conditions and the need to clarify the signs of forces involved. There is also mention of differing values for distance traveled, indicating potential discrepancies in calculations or assumptions.
KTiaam
Given the Information in the attachment and
m = 5.0 kg
a) find how far the mass moves before stoping
b) find it's velocity at t = 5.0s
i only need help on part B
Information i found from part A
distance = 4.72 meters
work = 19.6 Joules
I know you need to use Vo which is 2.8 m/s but I don't know what formula to use.
I was about to use:
v = vo + at
but i have no acceleration.
please help.
I got a slightly different number for distance traveled.
acceleration: how about F/m? And remember signs ...
ah i completely forgot about
F = ma
I found Force by dividing Work over Distance
Then I used f=ma
Found a = -0.83
Then I used V = Vo + at
and got V = -1.36.
which is the answer thank you for your help
Thank you.
F = ma
Then I used f=ma
Found a = -0.83
and got V = -1.36.
Thank you.
Yer' welcome. You could also have used F = 4.8cos30.
(P.S. I misread F = 4.8. You got the right answer for distance as you know by now.)
