Freely Falling Inertial As Seen By Distant Inertial Observer
The discussion revolves around the calculation of time and space dilation for an observer (B) falling toward a planet as perceived by a distant observer (A) in deep space. The scope includes concepts from special relativity (SR) and general relativity (GR) in the context of gravitational effects on spacetime.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant suggests that GR is necessary whenever gravity is involved, which is the case in this scenario.
  • Another participant argues that A's frame of reference (IRF) cannot be considered a global inertial frame due to the presence of gravity, indicating that GR is required for accurate calculations.
  • A later reply emphasizes that it does not make sense to refer to an "SR piece" in this context since the spacetime is not flat near the planet.
  • However, it is noted that far from the planet, in the vicinity of A, SR can be used as a good approximation because the spacetime is approximately flat, but this would not suffice for modeling B's motion as B approaches the planet.
Participants generally agree that GR is necessary for calculations involving gravity, but there is some contention regarding the applicability of SR in different regions of spacetime.
The discussion highlights the limitations of using SR in non-flat spacetime and the dependency on the proximity to gravitational sources, but does not resolve the implications of these limitations on the calculations discussed.
1977ub
Apologies if this is in a FAQ somewhere.
A is out in deep space.
B is falling toward the planet.
Does A need both SR & GR to calculate B's time/space dilation as determine by A's IRF?
You need GR anytime gravity is involved which it is in this case.
What you are calling "A's IRF" is not actually a global inertial frame. Locally, near A, it will look like an inertial frame; but it will *not* look like an inertial frame closer to the planet. There is no such thing as a global inertial frame when gravity is present. So you will need GR, as ghwellsjr says.
Thanks. so basically it doesn't even make sense to speak of an "SR piece" since the spacetime is not flat there.
Correct. Far enough away from the planet, in the vicinity of A, you can still use SR as a good approximation since the spacetime is approximately flat there. But that won't allow you to model B's motion since B does not remain far away from the planet.
  • · Replies 18 ·
  • · Replies 66 ·
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 21 ·
