History of speed of the expansion of the universe?
In summary, the applet "CosmoCalc" can be used to calculate the Hubble constant and redshift for lookback time. The applet will also tell you the percentage growth rate of distances back in the past. The current rate of distance growth is 1/140% per million years. Past epochs are labeled by how much distances and wavelengths have been elongated since that time (the "stretch" factor). The applet can be used to convert from a percent growth rate to a km/s speed of some benchmark distance.
SpaceBear
27
I would like to know the history of the value of the speed of the expansion of the universe.
If today it's 74.3 ± 2.1 kilometres per second per megaparsec then how much it was a billion years ago, 5 billion years ago, 10 billion years ago, and how much it was in the first million years after the Big Bang?
Also when the universe was approximately 379,000 years old, when the photons started to travel freely through space.
Astronomy news on Phys.org
That great! How were you intending to find out?
In the absence of dark energy, the Hubble Constant would be inversely proportional to cosmic age. With dark energy, it initially falls that way but settles down to a constant value in the far future so the maths is more complex.
There is an applet called "CosmoCalc" in a number of varieties that tells you lots of interesting parameters. This one from Ned Wright tells you redshift from lookback time:
http://www.astro.ucla.edu/~wright/DlttCalc.html
This one takes redshift and tells you lots of stuff including the Hubble Constant
http://www.einsteins-theory-of-relativity-4engineers.com/cosmocalc_2010.htm
They need to use the same assumptions for current values so set H0 to 70.4 and Omega_M to 0.272 in Wright's. Put in say 5 for the light travel time in Gyr and press the "Flat" button. You get 0.492 for the redshift.
Now put that value in for redshift in the second applet and it will tell you everything you want to know (and more).
The "speed" of the expansion of distances is proportional to the size of the distance. A distance twice as big increases at twice the "speed". Expansion rate is really not anyone particular "mph" or "km/s". It is a percentage growth rate of distance.
The current rate distances are growing is 1/140 percent per million years.
In the past the percentage growth rate was considerably larger. Here is a sample history:
[tex]{\begin{array}{|r|r|r|r|r|r|r|} \hline S=z+1&a=1/S&T (Gy)&T_{Hub}(Gy)&D (Gly)&D_{then}(Gly)&D_{hor}(Gly)&D_{par}(Gly)\\ \hline10.000&0.100000&0.6&0.8&30.825&3.082&4.663&1.585\\ \hline9.000&0.111111&0.7&1.0&29.922&3.325&5.081&1.861\\ \hline8.000&0.125000&0.8&1.2&28.856&3.607&5.583&2.227\\ \hline7.000&0.142857&0.9&1.4&27.570&3.939&6.197&2.729\\ \hline6.000&0.166667&1.2&1.8&25.976&4.329&6.964&3.449\\ \hline5.000&0.200000&1.6&2.3&23.932&4.786&7.948&4.548\\ \hline4.000&0.250000&2.2&3.2&21.181&5.295&9.247&6.373\\ \hline3.000&0.333333&3.3&4.9&17.215&5.738&11.008&9.819\\ \hline2.000&0.500000&5.9&8.1&10.915&5.458&13.361&17.878\\ \hline1.000&1.000000&13.8&14.0&0.000&0.000&15.793&46.686\\ \hline\end{array}}[/tex]
Past epochs are labeled by how much distances and wavelengths have been elongated since that time (the "stretch" factor). The table goes from S=10 to S=1 (the present moment).
You can read off the percentage growth rates from the "Hubble time" column (the fourth column).
In that column 14.0 Gy corresponds to the present rate of 1/140 percent per million years.
And 0.8 Gy corresponds to the rate of 1/8 percent per million years.
That was the rate back in year 600 million (i.e. in year 0.6 Gy) as you can see from the table.
The same calculator will easily tell you the distance growth rate at S=1090, the moment of clearing or transparency that you asked about. Around year 380,000 when the ancient CMB light originated. That light has been "stretched" by a factor of 1090 so you just have to put that number in the upper limit box, instead the number 10, which I put into make this table.
If instead of a percent growth rate, what you want is a km/s speed of some benchmark distance, I would suggest a million lightyears. Most people have some mental association with that distance---having heard the distance to a neighbor galaxy like Andromeda expressed in those terms. It is on the order of a million lightyears from us and its light takes on the order of a million years to get here.
When distances are growing at rate of 1/140% per million years, then a distance of 1 million lightyears is growing at a "speed" of 3000/140 km/s.
All you have to do, to convert, is multiply the percent rate 1/140 by 3000. That gives the km/s.
The same calculator will tell you that back at the time CMB originated distances were increasing by 157% per million years.
So if you want a "speed" of some sample benchmark distance, say 1 million lightyears. Just multiply that by 3000
3000 x 157 is some number of kilometers per second.
I would rather think of that in the equivalent form of 157% of the speed of light. Kilometers per second don't seem too meaningful in that range, an awkward unit to use.
But "speed" is an awkward way to visualize distance expansion in any case. What we are talking about is geometry change, not things traveling from one place to another. Nobody gets anywhere by expansion, all stationary observers just become farther apart.
And the expansion is proportional to the size of distance---you shouldn't have to pick a benchmark of a million this or that, you just make unnecessary work for yourself by doing that.
For convenience I keep the calculator link in my signature (TabCosmo7). Anyone who wants coaching in its use should ask. Several people here can help, and it's basically real easy to use.
1. What is the current understanding of the speed of the expansion of the universe?
The current understanding is that the universe is expanding at an accelerating rate, meaning that the speed of expansion is increasing over time. This was first observed by astronomer Edwin Hubble in the 1920s, and has been confirmed by numerous studies since then.
2. How fast is the universe expanding?
The speed of expansion is measured by a value known as the Hubble constant, which is currently estimated to be around 70 km/s per megaparsec. This means that for every 3.26 million light years, the universe is expanding by 70 kilometers per second.
3. Has the speed of expansion always been the same?
No, the speed of expansion has not always been the same. In fact, it is believed that the expansion of the universe has been accelerating since the Big Bang. This acceleration is thought to be caused by a mysterious force called dark energy, which makes up around 70% of the total energy in the universe.
4. How is the speed of expansion of the universe measured?
The speed of expansion is measured using a variety of techniques, such as observing the redshift of distant galaxies or analyzing the cosmic microwave background radiation. These measurements can then be used to calculate the Hubble constant and determine the speed of expansion.
5. Could the speed of expansion change in the future?
It is possible that the speed of expansion could change in the future, as the amount of dark energy in the universe is thought to be increasing over time. However, the exact nature of dark energy and its impact on the expansion of the universe is still not fully understood, so it is difficult to predict how the speed of expansion may change in the future.
  • Astronomy and Astrophysics
  • Cosmology
