How Many Reflections Appear Between Angled Mirrors?
  • Thread starter Thread starter fliptomato
    Images Mirrors
The discussion centers on determining the number of reflections visible between two angled mirrors, with specific parameters of mirror length (L = 1 meter), distance (D = 1 meter), and angle (\phi = 1 degree). A recursive formula, d(\theta, n), is proposed to calculate the distance between the observer and the nth image, where \theta is the angle of observation and n is the number of reflections. The key conclusion is that the number of visible images is contingent upon the angle \phi and the number of bounces n, with the condition that d(\theta, n) must equal L for the nth image to overlap with the observer's position.
  • Understanding of geometric optics and reflections
  • Familiarity with recursive functions and their applications
  • Knowledge of angles in two-dimensional space
  • Basic principles of ray tracing in physics
  • Explore the derivation and applications of recursive formulas in geometry
  • Study the principles of ray optics and how they apply to mirror reflections
  • Investigate the mathematical implications of angles in two-dimensional reflections
  • Learn about the behavior of light rays in angled mirror systems
Students studying geometry and optics, physics enthusiasts, and anyone interested in the mathematical modeling of reflections in mirror systems.
fliptomato
Hi everyone--I've been mulling over a homework question from earlier in the term:
Suppose you are standinig in the middle of two mirrors of length [tex]L[/tex] separated by a distance [tex]D[/tex]. ((i.e. if you are standing at the origin, the centers of the two mirrors are at [tex]x=\pm \L/2[/tex])) The mirrors are at a relative angle [tex]\phi[/tex]. ((i.e. if the mirror behind you was in the yz plane, then the mirror in front of you will be rotated by [tex]\phi[/tex] in the xy plane))
The question is: how many images of yourself do you see in the mirror?
This seems like a purely geometry problem, given the constraints of [tex]L[/tex] and [tex]D[/tex], how many admissible angles [tex]\theta[/tex] (in the xy plane) will produce a ray that bounces around a certain number of times and ends up back at the starting point (with the added trivial subtlety that it must hit the front of your face, not the back of your head).
Anyway, I think I've got it down to a formula for [tex]d(\theta, n)[/tex] that is recursive in [tex]n[/tex], where [tex]\theta[/tex] is the angle at which you are looking at [tex]n[/tex] is the number of times (forward and back) that the ray is reflected. The problem is that this isn't particularly helpful to answer the question (how many images)!
The assigned problem gave the numerical values [tex]L, D = 1[/tex] meter, and [tex]\phi = 1[/tex] degree.
I have a copy of the solution for this case, but I can't even make heads or tails of it! (Indeed I'm skeptical if this is even the correct solution for this problem.)
I've posted this at:
http://www.stanford.edu/~flipt/upload/number3.pdf
Any feedback about my approach or a rough summary of what's going on in that solution set would be appreciated! (I'll take down the solution promptly after some discussion since it's not a good idea to leave such solutions online for next year's class!)
-Flip
Hi Flip,
First of all, great job on working through this problem and coming up with a recursive formula for d(\theta, n)! It shows that you have a good understanding of the geometry involved in this scenario.
To answer the question of how many images you would see in the mirror, let's take a step back and think about the concept of reflections. When you stand between two mirrors, you are essentially creating multiple reflections of yourself. The first reflection is in the front mirror, and the subsequent reflections are between the two mirrors. Each reflection creates a new image of yourself, and the number of images you see will depend on the angle between the two mirrors (\phi) and the number of times the ray bounces between the mirrors (n).
Now, let's consider the recursive formula you came up with, d(\theta, n). This formula represents the distance between the original point (where you are standing) and the nth image. So, if we know the value of d(\theta, n) for a certain angle \theta and number of reflections n, we can calculate the distance between each image and the original point.
To answer the question of how many images you see, we need to find the value of n that makes d(\theta, n) equal to the length of the mirror (L). This is because when the distance between the original point and the nth image is equal to the length of the mirror, the nth image will overlap with the original point and you won't be able to see it.
So, in summary, the number of images you see will depend on the angle between the mirrors (\phi) and the number of times the ray bounces between the mirrors (n). To find the value of n, you can use your recursive formula and set d(\theta, n) equal to the length of the mirror (L).
I hope this helps clarify things for you. Keep up the good work!
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 18 ·
