Optimizing Cost per Unit with Calculus
The discussion revolves around optimizing cost per unit using calculus. Participants are attempting to understand how to calculate the average cost per unit given a cost function, with a focus on the implications of using variables versus actual numbers.
  • Participants are questioning the definition of 'average' and how it applies in a calculus context. There are discussions about differentiating functions and the relationship between total cost and cost per unit. Some participants express confusion about how to express average cost in terms of variables.
The discussion is active, with participants exploring different interpretations of the problem. Some have provided numerical examples to clarify the concept of cost per unit, while others are probing deeper into the calculus aspects without reaching a consensus on the approach.
There is mention of a specific cost function and the need to find values for x, which introduces uncertainty regarding the application of calculus principles. Participants are also navigating the constraints of homework rules and the requirement to derive general expressions from specific examples.
Elihu5991
REFER TO IMAGE
SEE ABOVE
I haven't been able to start this question. I'm wondering how to find the 'average cost per unit'.
What is the definition of 'average'?
I'm aware of what average means, though how would I find it with calculus? That, I'm not familiar with. I've done averages with actual numbers, not variables. Should I first differentiate it or do something else?
If it costs C to build x units, what is the cost per unit?
Your asking me what the question is asking in a simplified manner. I'm asking how to find the average. I'm unfamiliar with finding it with function specified.
I'm just trying to get you to find the answer yourself. Put it in numbers if it helps.
If it costs $100 to build 10 units, what is the cost per unit?
If it costs $50 to build 1000 units, what is the cost per unit?
How do you solve those? Can you use your solution to find how to express generally (in terms of C and x) the average cost?
Wouldn't there be a relationship, so I would first have to differentiate it? Thus, that function would then be the one for the average cost per unit?
But it's asking for an actual value for x, which is throwing me off. Would I need to follow common procedure like other optimisation questions?
Elihu5991 said:
REFER TO IMAGE
SEE ABOVE
For the given const function, what would be the total cost of x units? What would be the corresponding cost per unit? (Forget the word 'average'; just look at the cost per unit).
Will it be x^3 or cubed x?, since the function is "wrapped" to ^3?
Which message/question are you responding to? Please use the correct "response" panel.
Forget about the equation. We need to take one step back. Please start with answering post #6.
@Ray
Sorry I'm on the iPad at the moment, so I can't just do that. I forgot to use the alternative.
I was replying to you.
@DrClaude
I don't now how to find an actual value of x when there's only one real number in the equation: 10?
Elihu5991 said:
@DrClaude
What are you not seeing? If x = 2, what is the total cost? What is the cost per unit? If x = 10 what are the total cost and cost per unit? If x = 7 what are the total cost and the cost per unit? If x = 25 what are the total cost and the cost per unit?
If you can figure out the cost per unit when the value of x is given, just do the same thing when the value of x is not given.
  • · Replies 25 ·
