How can I solve the integral of 1/(1+x^4) from 0 to ∞?
  • Thread starter Thread starter vokurka
    Dx Integral
The discussion revolves around evaluating the integral of 1/(1+x^4) from 0 to ∞, which falls under the subject area of calculus, specifically improper integrals and techniques of integration.
  • Participants have attempted various methods including integration by parts, substitutions, and numerical integration, but have not arrived at an analytical solution. Some participants suggest specific techniques such as partial fractions and contour integration, while others question the effectiveness of certain substitutions.
The discussion is ongoing, with participants exploring different approaches and sharing hints. There is no explicit consensus on a single method, but several suggestions have been made that may guide further exploration.
Participants mention the need for an analytical solution despite having performed numerical integration. There is also a hint regarding the factorization of the integrand, which may influence the approach taken.
vokurka
∫1/(1+x^4) dx, from 0 to ∞
I have tried integration per partes, several different substitutions and transformation into different coordinate system but i have always only found another equivalent integral that i was not able to solve... I have also performed a numerical integration, but i need an analytical solution...
Thanks
You should be able to work out the indefinite integral with one substitution. By the way, what is the derivative of the arc tangent?
Thanks
Partial fractions.
vokurka said:
∫1/(1+x^4) dx, from 0 to ∞ I have tried integration per partes, several different substitutions and transformation into different coordinate system but i have always only found another equivalent integral that i was not able to solve... I have also performed a numerical integration, but i need an analytical solution...
Thanks
Hint: ##x^4 + 1 = (x^2+1)^2 - (\sqrt{2}x)^2##. Rearrange, factorise.
Then use what Ray suggested.
Try substituting ##\sqrt{u}=x##.
Edit: Sorry, this doesn't actually work. Disregard!
You have a definite integral. I'd suggest using contour integration and the residue theorem if you know that technique.
  • · Replies 44 ·
  • · Replies 22 ·
