Question Involving Fluid Speed.
  • Thread starter Thread starter kevinnn
    Fluid Speed
In fluid dynamics, when water with air bubbles flows through a pipe that narrows, the air bubbles will expand. This phenomenon is explained by Bernoulli's equation, which states that the pressure in a fast-moving fluid is lower than in a slower-moving fluid. As the water enters the narrower section of the pipe, the increase in fluid speed results in a decrease in pressure, allowing the air bubbles to enlarge due to the reduced external pressure acting on them.
  • Understanding of Bernoulli's equation
  • Basic principles of fluid dynamics
  • Knowledge of pressure and flow rate relationships
  • Familiarity with the behavior of gases in liquids
  • Study Bernoulli's equation in detail
  • Explore the principles of fluid dynamics and their applications
  • Research the effects of pressure changes on gas behavior in liquids
  • Learn about flow rate calculations in varying pipe diameters
Students in physics or engineering, educators teaching fluid dynamics, and anyone interested in the behavior of gases in liquids under varying pressure conditions.
kevinnn
Water with air bubbles in it flows through a pipe that is wide and then gets narrower. As the water gets to the narrower section will the air bubbles get larger, smaller, or not change?
Bernoulli's equation. I tried to write it out but I was not sure how to do it without it looking messy and I don't have Microsoft Word on this computer.
I said that they will get larger because the pressure of a fast moving fluid is less than a slower moving fluid. with this in mind the bubbles would be able to expand because the pressure acting on them is now less. Is this correct? Thanks.
-Kevin
Right on.
Cool thanks.
  • · Replies 16 ·
  • · Replies 61 ·
