Projectile motion of car hitting the ground
The discussion revolves around a physics problem involving projectile motion, specifically analyzing a car's motion as it accelerates up a ramp and subsequently becomes a projectile after leaving the ramp. The problem includes determining the angle of the ramp and the time it takes for the car to hit the ground.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to find initial velocity components in both x and y directions and explore the relationship between the ramp's angle and the velocity. There are inquiries about using trigonometric functions to derive these components from the given velocity magnitude and angle.
Some participants have made progress in calculating the angle of the ramp and the components of the initial velocity. There is an ongoing exploration of how to apply these components to solve the projectile motion equations, with some expressing uncertainty about the next steps while others confirm their calculations.
Participants note constraints such as a limited timeframe for solving the problem and varying levels of familiarity with the concepts involved, which may affect their ability to engage with the problem fully.
Abdeln
(Assume no friction) A car that has a mass of 3970 kg is accelerated from an initial velocity of 0 up a ramp that is 50 meters long (the hypotenuse) and has a height above the ground at the end of the ramp of 10 meters. The velocity of the car at the end of the ramp is 150 km/hr. At the end of the ramp the car flies through the air as a projectile. What is the angle of the ramp in degrees? If the car starts up the ramp at time equal to 0 seconds, how many seconds later does the car hit the ground.
I know I have to solve for the initial velocities in the x and y direction but I honestly have no idea where to start in this problem--if anyone could just tell me a starting point--it'd be much appreciated.
The angle of the velocity is the angle of the ramp. Which you should determine from the sides given. Recall how the sine is defined.
I found the angle to be 11.53 degrees, what can I do from there?
How can you find x and y velocity ccomponents given the sine of the angle and the magnitude of the velocity?
I don't know. I was never taught that--he gave us a problem set and gave us 2 days to solve it.
If you knew the x and components of the initial velocity, would you be able to solve the problem?
I believe so, yes
Very well. If some velocity has components Vx and Vy, what is the magnitude of the velocity?
Wouldn't it be the SQRT(Vx^2+Vy^2) ? Using Pythagorean theorem?
That is correct. The components-magnitude stuff works like sides in a right triangle. So how can you get the components if you know the magnitude ( = hypotenuse) and the angle?
Oh, just you trigonometric functions and you get the y direction to be 10, and the x direction to be 49?
These are the sides of the ramp. You need to find the "sides" of velocity.
knowing that the magnitude of velocity is 150 km/hour?
Yes.
ok i changed the magnitude to m/sec to make it easier so it'd be 41.67 m/sec, that'd mean that the x direction it would equal 40.8 m/sec and the y direction would equal 8.3 m/sec. right?
Correct.
Would I now plug everything I have into the projectile motion equations?
Well, you said that given Vx and Vy you should be able to solve the problem. What is difficulty now?
I was unsure--I managed to solve it.
Good job!
  • · Replies 21 ·
