Angular acceleration of a beam?
The discussion focuses on calculating the time it takes for a beam to fall, emphasizing the relationship between angular acceleration and the angle of the beam. Key equations mentioned include torque = moment of inertia * angular acceleration and the kinematic equation s = -1/2gt² + Vt + s. The user suggests analyzing the problem through energy conservation principles and references the 'inverted pendulum' for further insights into deriving angular velocity as a function of angle, which avoids solving differential equations.
  • Understanding of angular acceleration and its relationship to torque
  • Familiarity with moment of inertia concepts
  • Knowledge of kinematic equations in physics
  • Basic principles of energy conservation in mechanics
  • Research the 'inverted pendulum' model for insights on angular motion
  • Explore energy conservation techniques in rotational dynamics
  • Study the derivation of angular velocity as a function of angle
  • Learn about the relationship between torque and angular acceleration in detail
Physics students, mechanical engineers, and anyone involved in dynamics and rotational motion analysis will benefit from this discussion.
risecolt
This problem is making me want to tear my hair off.
I am trying to calculate the time it takes for a beam to fall to the ground.
http://myweb.lmu.edu/gvarieschi/chimney/Graph1.JPG
It would be great if I could calculate the rate of change of angular acceleration, as the acceleration would depend on the angle.
The equation for momentum or torque = moment of inertia * angular acceleration = cos(angle) * arm * m*g
Here the arm would be equal to the distance from the point of rotation to the center of the mass of the beam.
The other equation I find useful is: s = -1/2gt^2 + Vt + s
Again, with changing acceleration, I am lost.
Consider an analysis based on energy. How fast must the bar be rotating as it passes through a given angle in order for total energy to be conserved?
That should then allow you to derive angular velocity as a function of angle.
That should lead you to a solution that does not involve solving a differential equation.
Google something called the 'inverted pendulum' for some insight how to solve this.
  • · Replies 138 ·
9K
  • · Replies 20 ·
