Prove:β (heat pump) is always less or equal to β(Carnot HP)
  • Thread starter Thread starter mek09e
    Heat pump Pump
The discussion centers on the proof that the coefficient of performance (β) for heat pumps is always less than or equal to the coefficient of performance for a Carnot heat pump (β(Carnot)). The proof involves using the first law of thermodynamics to express β in terms of heat transfers (Q_C and Q_H) and applying the second law to relate these to the temperatures of the cold (T_C) and hot (T_H) reservoirs. This establishes that the maximum achievable β corresponds to a Carnot cycle operating between T_C and T_H, confirming that β ≤ β(Carnot).
  • Understanding of the first law of thermodynamics
  • Familiarity with the second law of thermodynamics
  • Basic knowledge of heat pump operation and performance metrics
  • Concept of Carnot cycles and their significance in thermodynamics
  • Study the derivation of the coefficient of performance for various heat pump cycles
  • Learn about the mathematical formulation of the Carnot cycle
  • Explore real-world applications and limitations of heat pumps
  • Investigate the implications of the second law of thermodynamics on energy efficiency
Students of thermodynamics, engineers working with heat pump technology, and anyone interested in the principles of energy efficiency in thermal systems.
mek09e
Hello All!
My professor in thermodynamics showed us the proof of the Carnot theory using integrals and a temp vs. entropy plot for a heat engine cycle. We haven't actually learned about entropy yet, so can someone help me understand how this translates into the coefficient of performance β for a heat pump? We were given the rule that β≤β(Carnot) for heat pumps and refrigerators, but I can't prove this is true on my own. Any explanation is appreciated :)
Don't you have a textbook?
Basically, you start from the definition of the coefficient of performance and use the 1st law to write it in terms of ##Q_C## and ##Q_H##, the heat coming from the cold reservoir and that going to the hot reservoir, respectively. Then, you use the 2nd law to translate ##Q_C## and ##Q_H## to ##T_C## and ##T_H##. This gives you the highest ##\beta## possible according to the 2nd law. Then you prove that a Carnot cycle working between ##T_C## and ##T_H## has a value of ##\beta## that is the highest possible. Therefore, ##\beta \le \beta(\mathrm{Carnot})##.
  • · Replies 19 ·
14K
14K
  • · Replies 67 ·
24K
