Triprotic Acid Titration Exact Calculation
The discussion revolves around calculating the analytical concentrations of KOH and H3PO4 in a titration scenario where H3PO4 is titrated with KOH until a specific pH is reached. The conversation includes theoretical aspects, mathematical reasoning, and challenges related to the application of mass and charge balance equations in the context of triprotic acid behavior.
  • Homework-related
  • Post 1 outlines the problem of determining the concentrations of H3PO4 and KOH after titration, emphasizing the unknowns involved in the calculations.
  • Some participants suggest using the final volume of the solution to express concentrations in terms of the initial moles of H3PO4 and the volume of KOH used.
  • There is a discussion on how to express anion concentrations in terms of dissociation constants and the concentration of H3PO4, with some participants seeking clarification on this step.
  • Participants express uncertainty about how to eliminate variables from the equations, particularly in relation to the concentrations of different species involved in the titration.
  • Some participants propose a systematic approach to derive expressions for the concentrations of the various species based on the equilibrium constants.
  • There is a back-and-forth regarding the correct application of the mass balance and charge balance equations, with participants attempting to clarify their understanding of the relationships between the concentrations.
  • One participant arrives at expressions for the concentrations of the anions in terms of H3PO4 and the dissociation constants, indicating progress in the calculations.
  • The conversation highlights the iterative nature of the problem-solving process, with participants building on each other's contributions and seeking further clarification at each step.
Participants generally agree on the need to express concentrations in terms of known variables and constants, but there is no consensus on the best approach to eliminate certain variables or on the specific steps to take next. The discussion remains unresolved as participants explore different methods and clarify their understanding.
Some participants note that the amounts of [H+] and [OH-] are negligible compared to other species in the solution, suggesting that these can be omitted from certain equations. The discussion also reflects the complexity of dealing with triprotic acids and the challenges in combining mass and charge balance equations effectively.
Big-Daddy
Calculate the analytical concentrations C2[KOH] and C2[H3PO4] in a solution where H3PO4 (originally of concentration 0.2 moldm-3 and volume 0.250 dm3) is titrated with KOH (originally of concentration 0.8 moldm-3, unknown volume used) until the pH reaches 7.8.
Mass balance: C2[H3PO4]=[H3PO4]+[H2PO4-]+[HPO42-]+[PO43-]
C2[KOH]=[K+]
Charge balance: [H+]+[K+]=[H2PO4-]+2*[HPO42-]+3*[PO43-]+[OH-]
Equilibria:
Kw=[H+]*[OH-]
Ka1=[H2PO4-]*[H+]/[H3PO4]
Ka2=[HPO42-]*[H+]/[H2PO4-]
Ka3=[PO43-]*[H+]/[HPO42-]
The unknowns are: [OH-], [PO43-], [HPO42-], [H2PO4-], [H3PO4] and [K+]. These number 6; we have 6 equations. So a solution exists. [OH-]=Kw/[H+], but what about the rest?
My problem is that C2[H3PO4] and C2[KOH] are unknown of themselves. They represent the analytical concentrations of H3PO4 and KOH in the final solution (of pH=7.90) after they have been added together. These are unfortunately the two values we need to work out in the end.
Assume V as the final volume of the solution. Then C2[H3PO4] would be equal to n/V where n is the initial number of moles of H3PO4.
Now write the anion conc. in terms of the dissociation constants and [H3PO4] plug these in the mass equation to get [H3PO4] in terms of V.
Now in the charge balance equation, [K+] is equal to 0.8*(V-0.25)/V, the anion concentrations are also in terms of V and [H+] is known. Thus V can be found and hence the analytical concentrations.
Can you demonstrate how to write the anion concentrations in terms of dissociation constants? It's this step I always have trouble with for this type of calculation (i.e. the tough step is combining the mass balance and charge balance equations; I can do it sometimes, but not usually for triprotic/diprotic acids).
C2[KOH]=[K+]
Equilibria:
Kw=[H+]*[OH-]
Amounts of [H+] and [OH-] are utterly negligible compared to other things in these conditions so just leave them out of eq. 2. [K+] is the same thing as [KOH]. OK after you have done your main calculation with molarities you finally express in terms of a volume.
Getting the requested equation is just a matter of applying the equilibrium equations you have written. You have to write your [H2PO4-] in terms [H+] and Ka1, you practically have the expression for that bit, then you have to do it successively for the others and include them - you will get an [H+]2 and [H+]3 term.
Thanks, but in trying to get my [H2PO4-] in terms of [H+] and Ka1 how do I get make [H3PO4] cancel down?
Check out post #2.
Don't.
Don't worry for the moment and if we are taking it step by step don't ask me what to do after the step you haven't shown.
epenguin said:
Don't.
According to your post this is the first step? You wrote: "You have to write your [H2PO4-] in terms [H+] and Ka1, you practically have the expression for that bit". In any case the problem still applies if I am to find [H3PO4] first: how do I get rid of [H2PO4-] from the expression?
Perhaps if you could demonstrate for one of them, I will carry it on successively for the others.
OK what I'm trying to get you to do is write all the species' concentrations in terms of [H3PO4] and at the end you will apply your mass balance equation. So just use your Ka1 equation to write [H2PO4-] =
Very simple.
Very simple.
OK, so by substituting this successively we reach: [PO43-]=[H3PO4]*Ka1*Ka2*Ka3/([H+]3). Now what?
OK you've got the last one - have you got the first one that I asked? And the second one?
(for [HPO42-] = ?)
Write them down too please.
(for [HPO42-] = ?)
[H2PO4-]=[H3PO4]*Ka1/[H+]
[HPO42-]=[H3PO4]*Ka1*Ka2/[H+]2
I'm beginning to see where this is going. Next we're going to substitute in for each term in the mass balance?
Yes. But give us the result. :smile:
C2[H3PO4]*[H+]3=[H3PO4]*([H+]3+Ka1*[H+]2+Ka1*Ka2*[H+]+Ka1*Ka2*Ka3)
And now what? We have neither C2[H3PO4] and [H3PO4].
You do have C2[H3PO4], it's in the second line of the thread.
[H3PO4] is what you are trying to find the formula for. You have everything else and could now write
[H3PO4] = ...
Maybe you don't recognise what an answer would be, and in general it would be
[H3PO4] = C2[H3PO4] X (function of the K's and [H+])
and that is the important one. In this case C2[H3PO4] can be given a number that they want you to work out.
[H3PO4] = ...
No, we have C1[H3PO4] (the original analytical concentration). C2[H3PO4] is the analytical concentration of H3PO4 once H3PO4 was combined with a certain unknown volume of NaOH to produce the solution of pH = 7.8. How do we find either C2[H3PO4] or [H3PO4]?
Now you tell me! I'm sorry, this is the first time this C1 has been mentioned and you have asked a question without ever defining what the terms you ask about meant (!) so I just went on assumption and how suchlike questions are treated always.
Never mind, it is always much the same thing and you can expect to meet similar questions again and again and they are always dealt with by the same routine. And you do have the information for the calc.
So I'll just write the various concentrations in rational form - molarities - what need is there for C1, C2 etc? There is a total of all forms of the phosphate which you are given the information to calculate, this will usually be known or knowable, and even when it isn't you still formulate the same equations in terms of it algebraically. So here I'll call it [P]tot, actually it does equal the total molarity of phosphorus in the solution so the tot is just added mind label.
So I'll rewrite the last line of my last post as
[H3PO4] = [P]tot X (function of the K's and [H+])
You can start by writing [P]tot = function given by the mass balance equation with your equilibrium equations enabling you to write in terms on one concentration.
By which you can calculate [H3PO4] if you know (as you do) [P]tot, [H+] and the K's.
Likewise you can get an equation for and calculate the concentrations of all the four forms of phosphate at any given pH.
I have to answer this in more than one post because of connection and seeing screen probs.
Things you should realize:
The LHS of your mass balance equation should be, in my terms [P]tot, which is what I assumed you meant.
Before you do the calculation of [H3PO4] I hope you'll realize that it's going to be quite tiny - of the order of less than 10-5 of the main components at pH 7.8. [PO43-] will be likewise negligible.
To solve the rest of your problem you are going to have to calculate [H2PO4-] and [HPO42-] preferably as fractions of [P]tot, similar kind of calculation to that for [H3PO4].
The other part of your problem was to calculate [K+] . How are you going to do that? Well think, as well as mass balance what other kind of balance is there here? :wink In fact you already have an equation for [K+].
I remind you we said [H+] and [OH-] are negligible. I think what throws students is the fact that these seem all important, the questions are about them, and yet at the same time they are negligible though some of the equations involve them vitally, in others they are ignored. Think of them as reporters on the state of the system and on the balance between the big players there in mass.
In fact there are only two forms of phosphate that matter in this question H2PO4- and HPO42-
Therefore actually you can solve it using pretty much the theory you will have already done with monobasic acids. And in any case even the full theory for tri- or multi- protic acids is scarcely different from that you have already done for mono-, the only difference is that there are more terms. We often like to write the more general equations first, and then home down on any particular simplifications for particular cases. In the case that the pK's were closer together we'd have to keep the more general ones.
And I have to say you are taking days to grind out equations that people write in fewer minutes. Conservation equations and equilibrium equations + any simplifications, that's it. In chemistry and biochemistry you'll meet any number of equations like that for multiple equilibria, you'll see them just written down with minimal explanation, maybe definition of the eq. constants by equations, maybe a conservation equation or two, maybe not because considered obvious. You should see what all the terms and the pattern are saying.
I nay not have time next days to continue this, anyone is welcome to take over if nec.
Edit: other obscure terminology - I don't know what is meant by 'analytical' :confused: concentrations, unnecessary adjective?
In my (rational and standard :-p) terminology your eq. of #14
[P]tot[H+]3=[H3PO4]*([H+]3+Ka1*[H+]2+Ka1*Ka2*[H+]+Ka1*Ka2*Ka3)
appears correct.
You just need to express that as
[H3PO4] = ...
and answer the rest of the question.
I see now, thank you. :)
Since this method involves fairly long computation I was wondering if we could now work on an approximate shortcut. When I asked this elsewhere (not specifying the need for an exact solution) I was told that we need only consider the two species of the acid involved in a pKa value which is within 3 units either way of the pH (assuming no other pKa value is also within 3 units of the pH, which is true for phosphoric acid - pKa2 is the only pKa within 3 units of the pH). So we need only consider [HPO42-] and [H2PO4-] - makes sense so far. I was then told the first step is to calculate the [HPO42-]/[H2PO4-] ratio. This is fairly easy: [HPO42-]/[H2PO4-]=Ka2/[H+]. But do you have any idea how we might proceed from here?
Perhaps I should clarify what we're looking for. C1 of any acid or base is the total initial concentration of that acid or base in the solution it was originally in (e.g. we're given 0.80 M for the base). C2 of any acid or base is the "initial" (and by this I mean the "total" - this is the collected concentration of all the forms of the acid in the solution) concentration of that acid or base, in the new solution into which they have been placed. With that in mind, the values we now seek are C2 for both the acid and base.
If you read back you'll see I said e.g. #18 only these two are significant quantitatively at this pH.
I would be surprised if they had set you to calculate the triprotic formula and had never done with you the simple monoprotic one to which it practically simplifies in this case. Check back course notes or textbook.
The general triprotic formula which you were asked is NOT any 'long' computation and you are almost there. You just need now to give the formula [H3PO4] =
Then it is easy to calculate its numerical value at the pH of the problem and you will see it is, as I said :rolleyes:, tiny. Likewise you can calculate the value of the two species that are important now.
The principles of the simplified case about which you ask now are just the same. You have a ratio, call it A/B. From mass balance you have the sum (A + B). **
* (My guess at what is stopping you so long is the frequently observed fact, what students did in very elementary algebra five or ten years ago, they can't do or recognise any more when the same thing is called 'chemistry'.)
**I do draw the line I'm afraid at explaining how to work out A and B.
First part of your post:
My problem which still persists is that I can write this:
[H3PO4]=Ca2*FA (FA is the acid dissociation function you alluded to earlier)
So:
[H3PO4]=Ca2*[H+]3/([H+]3+[H+]2*Ka1+[H+]*Ka1*Ka2+Ka1*Ka2*Ka3)
But I don't have the value of Ca2 (the initial concentration of the acid, in the solution with both acid and base) as I don't know what volume I added to my original concentration. I have the total moles of acid (let's call it n[H3PO4], I don't see what's unreasonable about that) which stays constant during titration, but the concentration will have changed from Ca1=n[H3PO4]/Va to Ca2=n[H3PO4]/(Va+Vb). I simply do not understand how to compensate for this problem.
I come up against the same problem using the approximate method (as you say, the principles are the same). You write the mass balance as Ca2=[HPO4-]+[H2PO4-] and thanks to the ratio I found in my earlier post it is easy to place the expression in terms of just 2 variables, but we know neither the total concentration of acid Ca2 nor either of the species concentrations. This is clearest when Ca2 is replaced with n[H3PO4]/(Va+Vb), and you have two unknowns: Vb, and whatever acid species form you substituted for from the ratio. Trying to work out either of the two acid forms always seems to require Ca2, which we do not have since we don't know how much base was used to titrate the acid.
My basic algebra is fine.
Edit: The derivation of the species concentration in terms of [H+] is nice, I must thank you for showing me it. Unfortunately I can't see how to use it in the case of a titration (clearly the expression is the same, but the starting concentration of the acid is not anymore).
So:
Finally you stated the general formula for the concentrations of one of the species present in a phosphate solution created by adding some alkali to phosphoric acid. For the record in my terminology this is just
[H3PO4] = [P]tot[H+]3/([H+]3+Ka1*[H+]2+Ka1*Ka2*[H+]+Ka1*Ka2*Ka3)
The other three species' concentrations can be given in just the same way. The denominator would be the same for all of them and the numerator different, one term that also appears in the denominator. Lots of equations of this general kind come up all the time, when you have as often multiple equilibria, the equilibrium equations are combined with (one or more) mass balance equations. It is not higher math but elementary algebra applied to a physico-chemical situation and laws. Almost accountancy.
If algebra is not the problem I wonder if a confusing terminology is.
Anyway you say the volume of KOH added is unknown. You can know. We talked above of [K+].Just imagine the KOH added was concentrated and effectively didn't change the volume. From the pH, the K's, work out the concentrations of the two important forms of phosphate. Hence work out what [K+] is. You know the concentration of KOH used, so you can know the volume added. Then you can correct for the dilution (a somewhat secondary point IMHO).
There's no way we can assume the KOH added didn't change the volume, because we're given the concentration - 0.80 M - and this is certainly not enough to make the 0.2 M (originally) H3PO4 concentration seem negligible.
I'm wary of trying to post-correct for dilution when I imagine it will have an enormously serious effect. We could well be adding 0.050 dm3 (50 cm3), maybe slightly more, to a 0.250 dm3 solution.
Perhaps I am to use the charge balance to work out [K+], then this is equivalent to what I notated as C2[KOH] in my original mass balance for K, and this enables us to work out the Vb used after which it all falls into place?
I think subtleties are coming up that don't affect the issue. Whatever you think dilution does you have been told the pH at the end of the procedure. That fixes the ratio of the two phosphate forms. (From that point you can reason in terms of total moles rather than concentration if you wish, may make it easier.) So you can get the moles of each form. That in turns fixes moles of K+ that have been added. I think that is all watertight. After that you can think about what this implies for final volumes and concentrations.
The part in bold is where you've lost me.
I have an expression like this for each species (using your notation):
What then is [P]tot? How do we calculate that? This is our big question.
OK maybe I didn't see your point because I wouldn't do it in a way that causes this problem.
Just do it by moles then as per my last post which appears simplest.
You could do it by concentrations defining a volume = (0.25 + VKOH) or something (nothing's stopping you) but I don't think personally it is worth the trouble and that it distracts from essentials.
Hmm but I don't have the moles of H+, only the concentration in solution.
I will make evident where this brings in a problem: Ptot[H3PO4]=neq[H2PO4-]+neq[HPO42-] (neq is the number of moles at equilibrium of the species in the brackets) and Ka2/[H+]=[HPO42-]/[H2PO4-] but this is in concentrations, so what do we do? And I'm not sure you can do this but if we simply convert each concentration to a number of moles we'll end up with Ka2/(V*[H+])=[HPO42-]/[H2PO4-]. This means that our substitution of this ratio into the mass balance I wrote for P won't manage to exclude V.
I think your teachers are less likely to notice your concern for accurate figures than your failure to come up with even any crude ones, and could take this for total lack of grasp! In a lot of these things exact concentrations don't matter nearly as much as proportions or ratios and also orders of magnitude.
It is really time you put some numbers on this fifteen-minute problem on which you are stuck for almost as many days, so you can do the following:
For the first question, you can calculate straightaway [H3PO4]/[ P]tot at pH 7.8. If that is a very small number that's all you need to be able to say [H3PO4] is so small it can be ignored. Even without this concern for the volume change which if you ignored you'd be only about 10% out. Even if the concentration mattered, 10% more negligible is still negligible! But the calculation justifies instead of assumes that you can ignore it. Likewise calculate and state the same justification for [PO43-].
Then calculate what is the ratio of the two remaining forms of phosphate at pH 7.8? (You only need [H+] for this - see your own equations*.) The ratio of the concentrations or molarities and the ratio of the amounts or moles are exactly the same, since they are in the same beaker. Hence how many moles of each phosphate species are there? Hence calculate how many moles of K+ are there? Hence you can calculate how many ml of KOH was added. Then you have all these volumes and accurate concentrations that you want.
* in your first post - not this one Ka2/(V*[H+])=[HPO42-]/[H2PO4-] - where has that V come from?
I'll go with the approximate method (so the only two phosphate species we need to worry about are [HPO42-] and [H2PO4-]. You've clarified things a great deal in your last post, most importantly with the note that the ratio of concentrations is the same as the ratio of moles (which should have been obvious but for some reason wasn't!).
We started with Ptot mol H3PO4 acid. So Ptot=n[H2PO4-]+n[HPO42-] and from the ratio equation we get Ptot=n[H2PO4-]+(Ka2*n[H2PO4-]/[H+]).
Now we solve for n[H2PO4-]=Ptot*[H+]/([H+]+Ka2). My worry previously was that we could not work with [H+] like this because this is a concentration and everything else is moles, but now I'll proceed with the realization that because the ratios of concentration and moles are the same it makes no difference. n[H2PO4-]=0.2*0.250*(10^(-7.80))/((10^(-7.80)+(10^(-7.20))=0.010038 moles roughly. n[HPO42-]=0.039962 mol by subtraction.
How do we proceed to calculate n[K+]? Although we could easily use the charge balance in terms of number of moles, we would still be lacking n[H+]. We have n[H+]+n[K+]=0.010038+2*0.039962. But this must be the wrong route as without V we cannot work out n[H+] from [H+].
9K
13K
