Meaning of specifications for SDS rotary hammers?
  • Thread starter Thread starter Stephen Tashi
    Rotary
The discussion clarifies that the "1 inch" specification in SDS-plus rotary hammers, such as the "Makita 1 inch D-Handle SDS-PLUS," indicates the maximum recommended diameter of the drill bit that can be used effectively with the tool. All SDS-plus shanks maintain the same dimensions, confirming that while a 1 1/16 inch bit can fit, it may strain the drill motor. Users are advised to select a drill motor rated for a larger diameter than the bit being utilized to prevent overworking the tool.
  • Understanding of SDS-plus chuck specifications
  • Knowledge of rotary hammer drill mechanics
  • Familiarity with drill bit dimensions and compatibility
  • Awareness of motor ratings and performance limits
  • Research the specifications of various SDS-plus rotary hammers
  • Learn about drill bit sizes and their impact on tool performance
  • Explore the differences between SDS-plus and SDS-max systems
  • Investigate best practices for selecting drill motors based on bit size
This discussion is beneficial for contractors, DIY enthusiasts, and tool users who require a clear understanding of rotary hammer specifications and their implications for effective drilling operations.
Stephen Tashi
Education Advisor
Online, I see SDS-plus chuck rotary hammers with specifications like "Makita 1 inch D-Handle SDS-PLUS". What does the "1 inch" specify?
I think the shanks of all SDS-plus bits have the same dimensions. So does the "1 inch" refer to the largest diameter bit that is recommended for use with the hammer? Wouldn't a 1 1/16 diameter SDS-pus bit fit in the chuck of a "1-inch" SDS-plus hammer? Or does "1 inch" refer to the length of the hammer stroke?
You are correct that all sds+ shanks are the same size, and the 1" is the maximum recommended diameter bit.
A larger bit will fit, but may overwork the drill motor. Always use a drill motor rated for a larger diameter than you are going to use.
  • · Replies 42 ·
9K
21K
