How to find the difference in hieght in a u-tube(Please help)
  • Thread starter Thread starter Stretch999
    Difference
The discussion focuses on calculating the difference in height in a U-shaped tube based on fluid dynamics principles. The problem involves a horizontal pipe with a cross-sectional area of 40.0 cm² at the wider section and 10.0 cm² at the constriction, with a water discharge rate of 6.00 x 10⁻³ m³/s. The calculated flow speeds are 1.5 m/s at the wide section and 6.0 m/s at the constricted area, leading to a pressure difference of 16,875 Pa. The height difference in the mercury columns was initially calculated as 0.127 m, which was later questioned for accuracy.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation.
  • Knowledge of the continuity equation (AV = volume flow rate).
  • Familiarity with the properties of fluids, including density (e.g., density of mercury ρHg = 13.6 x 10³ kg/m³ and water ρw = 1.0 x 10³ kg/m³).
  • Ability to perform calculations involving pressure differences and height in fluid columns.
  • Study Bernoulli's equation in detail to understand its application in fluid flow scenarios.
  • Learn about the continuity equation and its implications for flow rates in varying cross-sectional areas.
  • Explore the concept of hydrostatic pressure and its role in determining height differences in fluid columns.
  • Review examples of U-tube manometer calculations to reinforce understanding of pressure measurement in fluids.
Students studying fluid mechanics, engineers working with fluid systems, and anyone interested in practical applications of fluid dynamics in real-world scenarios.
Stretch999
Help! How to find the difference in height in a u shaped tube?
1. Homework Statement
The horizontal pipe, shown in the figure, has a cross-sectional area of 40,0cm2 at the wider portions and 10,0cm2 at the constriction. Water is flowing in the pipe, and the discharge from the pipe is 6,00∗10−3m3s(6,00Ls). The density of mercury is ρHg=13,6∗103kgm3 and the density of water is ρw=1,00∗103kgm3.
Find
a)the flow speeds at the wide and the narrow portions
b)the pressure difference between these portions
c) the difference in height between the mercury columns in the U-shaped tube?
hint(Express the pressure at the lower mercury-water interface in two ways and uzse these expressions to solve for h)
1 minute ago
- 4 days left to answer.
Additional Details
This is the image of the situation:
http://session.masteringphysics.com/problemAsset/1260675/1/YF-14-45.jpg
please can someone help
for a) i use AV=volume flow rate
b)used Bernoullis eqn and made the heights 0
c) used p=p1 and p=p2+density*g*h
a) got v at large area=6m/s
v at constricted area=1.5m/s
b)got difference in presure to be 16875pa
c)got 0.127m which is apparently wrong
Shouldn't the velocity in the constricted area be higher than the rest of the pipe?
Sorry i typed it in wrong they are the other way round
velocity at the constricted is 6m/s
velocity at the large is 1,5m/s
Did you use Bernoulli's equation of flow to get the pressure difference?
1. Homework Statement [/b]
Find
1 minute ago
Additional Details
a) got v at large area=1.5m/s
v at constricted area=6m/s
Yes i did you and made the heights 0 because they on the same level.
I can't see what is wrong with your calculations. They seem legitimate. What are the expected answers for pressure and velocities in your source?
I don't know that's the problem. I thought it was wrong because someone said that they got this answer and apparently it was wrong but now that you confirmed what I thought maybe he was wrong. Thanks
13K
9K
27K
