Liquid-Vapor Equilibrium and Vapor Pressure
by jaumzaum
Tags: equilibrium, liquidvapor, pressure, vapor
jaumzaum
jaumzaum is offline
#1
Mar25-13, 05:31 PM
jaumzaum's Avatar
P: 246
I'm studying vapor pressure and I'm having trouble to understand some concepts.
Vapor pressure depends only on the temperature of the liquid in question right? For example, if we have a container with water at 30 C, it doesn't matter the experiment, would it ALWAYS be a vapor phase with pressure = vapor pressure of water at 30C = 31.8 mmHg?
So consider the following experiment: In a container we have water at 30C. One end is closed while in the other we have a piston. Above the pistons we have weights that do a initial pressure of 200mm Hg on the water. Is there water in the vapor state? I would say yes, but if so the vapor should exert a pressure of 31.8mmHg, and where would be the other 268.2mm Hg? The only explanation I thought is that a few bubbles of gas above the liquid makes the 31.8mmHg but the liquid still stays in contact with the piston making the other 268.2 mmHg. But I haven't read this in anywhere, is it right?
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
jaumzaum
jaumzaum is offline
#2
Mar26-13, 04:41 PM
jaumzaum's Avatar
P: 246
Correction: "Above the pistons we have weights that do a initial pressure of 300 mm Hg"
Nobody knows the answer?
etudiant
etudiant is offline
#3
Mar26-13, 08:59 PM
PF Gold
P: 849
I do not see the need to subtract the vapor pressure anywhere. There is the same pressure beneath the piston as beneath the closed end, so the full effect of the piston weight is transmitted.
Chestermiller
Chestermiller is offline
#4
Mar26-13, 09:11 PM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 4,453
Quote Quote by jaumzaum View Post
There wouldn't be any vapor present. Assuming there is a vacuum above the piston, you would have to raise the temperature enough for the vapor pressure of water to equal the pressure applied by the weights (200 mm Hg). That would be about 66 C. Until then, you would only have liquid water.
jaumzaum
jaumzaum is offline
#5
Mar27-13, 11:10 PM
jaumzaum's Avatar
P: 246
I can't understand why!
When we look at the Maxwell-Boltzmann distribution of molecular energy we see that any liquid has some molecules with energy enough to pass to the gaseous state. On the surface of the example I gave, shouldn't be liquid water turning into water vapor?
Register to reply
Related Discussions
Why liquid boils when the envrionmental pressure equals its saturated vapor pressure General Physics 4
Vapor pressure and the boiling point of a liquid Introductory Physics Homework 2
Vapor pressure vs liquid pressure in enthalpic combustion reaction Biology, Chemistry & Other Homework 0
Estimating Vapor Pressure and Vapor Mole Fraction Biology, Chemistry & Other Homework 0
Calculating mass of vapor from vapor pressure Biology, Chemistry & Other Homework 4
