Deflection of beam after reaching elastic limit
The discussion revolves around the deflection of beams in relation to the elastic limit of materials, particularly focusing on how to account for material behavior when stress exceeds the elastic limit. Participants explore theoretical and practical implications in engineering contexts.
  • One participant notes that deflection calculations typically consider geometry and Young's modulus, but questions how to account for behavior beyond the elastic limit, where 'E' is no longer valid.
  • Another participant suggests that in engineering practice, it is common not to factor in behavior beyond the yield stress, advocating for design practices that avoid exceeding this limit.
  • A participant mentions that after the yield point, material behavior becomes nonlinear, complicating calculations and suggesting reliance on stress-strain curves and sample testing for specific materials.
  • There is a mention of numerical solutions for problems involving nonlinear material behavior, particularly for elastic-perfectly plastic materials, which can be modeled with specific stress-strain relationships.
Participants generally agree that exceeding the elastic limit complicates calculations and that it is preferable to design beams to remain within yield limits. However, there is no consensus on how to incorporate the effects of yielding into calculations, with multiple viewpoints on the best approach.
Participants acknowledge the limitations of existing formulas in accounting for nonlinear behavior and the dependence on material properties, manufacturing processes, and potential inclusions in the material.
k.udhay
Hi,
When we find out the deflection of beam, the factors considered are its geometry (moment of inertia) and young's modulus (E) of the material. As per text Hook's law 'E' is constant only till the elastic limit of the material. Assuming that the stress induced crosses the elastic limit, 'E' is no more valid. How do we take this effect in the calculation, if the stress is above elastic limit? Thanks.
In engineering, normally you don't. There's not a really good way to factor that into your formulas, so you should design the beam (or alter the loading condition) to something that won't induce a stress over the yield stress of the beam.
After the yield point, it starts to become nonlinear and there isn't a good way to account for that without really taking multiple things into account. In essence, you're cold working the beam by yielding it and making it harder, but only in certain regions. The more you cold work it, the harder and more brittle it becomes in those spots. After a while, cracks are induced and the beam catastrophically fails. The stress-strain curves for a specific material can help you determine how it will generally behave, but then it's also entirely dependent on how your sample was manufactured and any heat treatment it received. As well, if there are any inclusions in your specific batch of material, it could also affect its behavior.
So, short answer: we try not to take that into consideration. If you feel you need to do so, consult the stress-strain diagrams or do your own sample testing.
In general, you just have a statics or dynamics problem with nonlinear material behavior, and you have to solve it numerically.
A special case is for elastic - perfectly plastic materials, where the stress strain curve is modeled as two straight line segments. See http://en.wikipedia.org/wiki/Plastic_hinge
Thank you, Tim. So, it's safe to keep the component within its yield limit.
Thanks, Aleph. :)
10K
  • · Replies 30 ·
10K
