What does the Fortran 77 command 'write' do and how is it used?
  • Context: Fortran
  • Thread starter Thread starter Triscas
    Fortran
The discussion revolves around the Fortran 77 command 'write', specifically its usage and the meaning of the unit number in the context of output formatting. Participants are exploring how the command operates in a program, particularly in relation to formatting statements and output devices.
  • Some participants explain that the command 'write (4,*)' outputs a single space to unit 4 using a default format.
  • It is noted that 'write (4,310)' and 'write (4,311)' print formatted strings defined in format statements 310 and 311, which appear to serve as headers.
  • There is a question about the meaning of unit 4, with one participant suggesting it indicates the output device, likely a disk file associated with an OPEN statement.
  • Another participant queries whether the values will have a length of 4 characters, but this is not directly addressed.
Participants generally agree on the function of the 'write' command and its formatting, but there is some uncertainty regarding the specifics of unit 4 and its implications.
There is a lack of clarity regarding the specific nature of unit 4 and whether it is strictly related to character length or output device assignment.
Triscas
Hello,
I'm new using fortran and I don't know what does it mean:
write (4,*) ' '
write (4,310)
write (4,311)
this lines go consecutive in the programm I have to understand.
- might say that 4 is not a reference to a line of the code.
- 310,311 are references about how the format should be
i.e:
310 format('Distance C Elec C Sol Surf Liq Pot Solid Pot ',
&'Liq Cur j main j side 1 j side 2 j side 3')
311 format('(microns) (mol/m3) x or y (V) (V) ',
1' (A/m2) (A/m2) (A/m2) (A/m2) (A/m2)')
I hope someone can help. Thanks
Technology news on Phys.org
Triscas said:
Hello,
write (4,*) ' '
write (4,310)
write (4,311)
i.e:
All of your write statements send output to unit 4, the first number in the parentheses.
write (4,*) ' ' -- prints a single space (' ') on unit 4, using a default format.
write (4,310) -- prints the string in the format statement in line 310, on unit 4. This string appears to be a header of some sort.
write (4,311) -- prints the string in the format statement in line 311, on unit 4. This string also appears to be some sort of header.
what does unit 4 mean? The values will have a length of 4 characters?
yes, i also understood they're a header the other outputs. The second might be the units of the first
The unit number indicates which device you want to write to. In this case it would probably be a disk file that was assigned a unit number with an OPEN statement.
Thanks for the answer, Mark.
20K
