Finding the moment(s) of inertia
  • Thread starter Thread starter dinospamoni
    Inertia
The discussion focuses on calculating the moments of inertia (Ixx, Iyy, Izz) for a wedge of a sphere with a radius of 14 cm and a density of 4500 kg/m³, oriented with its axis along the z-axis and one face in the xz plane. The user initially struggled with expressing the differential volume element (dV) in terms of Cartesian coordinates and later successfully converted to spherical coordinates, utilizing triple integration to derive the correct values for the moments of inertia. Key equations used include I_xx = ∫(y² + z²)ρ dV, I_yy = ∫(x² + z²)ρ dV, and I_zz = ∫(y² + y²)ρ dV.
  • Understanding of moment of inertia concepts
  • Familiarity with integration techniques in calculus
  • Knowledge of spherical coordinates and their applications
  • Basic principles of density and mass calculations
  • Study the derivation of moments of inertia for various geometric shapes
  • Learn about triple integration in spherical coordinates
  • Explore the relationship between density, mass, and volume in physics
  • Investigate the symmetry properties of three-dimensional objects in mechanics
Students and professionals in physics and engineering, particularly those focusing on mechanics and materials science, will benefit from this discussion.
dinospamoni
A wedge of a sphere of radius 14 cm (similar to one
segment of an orange) is oriented so that the axis is aligned
with the z-axis, one face is in the xz plane, and the other
is inclined at an angle of α = 29o
, as shown. The wedge is
made of metal having a density of 4500 kg/m3
. In the coordinate system shown, compute a) Ixx, b) Iyy, and c) Izz.
The picture is attached
I know that
I_xx= ∫(y^2+z^2)ρ dV
I_yy= ∫(x^2+z^2)ρ dV
I_zz= ∫(y^2+y^2)ρ dV
I'm having trouble thinking of how to replace the dV with something in terms of x y and z
The first thing I did was find the mass, but I'm not sure if it would help at all
I did V=4/3 π r^3
and then multiplied by 29/360 to find the volume of the wedge and the multiplied by the density.
Also, just thought of this now:
r = (x^2 + y^2 + z^2)^1/2
could I differentiate the volume equation to find dV in terms of r and dr (4 pi r^2 dr)
and substitute in the above expression for r and just tack on dx dy and dz? SOrry if that breaks all rules of physics
I did V=4/3 π r^3
That does not help.
You can write dV = dx dy dz in cartesian coordinates. There are similar formulas for spherical coordinates and other coordinate systems.
y^2 + z^2 and similar expressions are not constant for constant r, this does not work. You will need more than 1 integral.
For I_zz, you can use the symmetry of the problem, if you know the moment of inertia of a ball.
After posting this I converted it to spherical coordinates and used triple integration and found the correct answers. Thanks though!
  • · Replies 27 ·
9K
