| Thread Closed |
Lens |
Share Thread | Thread Tools |
| Mar21-05, 03:31 PM | #1 |
Lens
Hi i have a question about a lens,im not sure if this is the right place to ask but il ask anyways...please help im really stuck!!
Question: An object is placed 24cm infront of a concave mirror of focal length 18cm. Where is the image formed and what is its magnification?Include an accurately dranw ray diagram?? |
| Mar21-05, 03:45 PM | #2 |
[tex]
\frac{1}{f} = \frac{1}{u} + \frac{1}{v} [/tex] where f is the focal lenth of the lense,v is the object distace and u the image distance. [note: allways good to say what you have allready tried!] that didn`t look quite right did it .... (latex is harder that i 1st thought!!) 1/f = 1/u + 1/v |
| Mar21-05, 04:18 PM | #3 |
Recognitions:
Zanazzi: Your slash before the ending tex tag should be forward not backwards
| Mar21-05, 04:42 PM | #4 |
Lens
This is an exercise that belongs in some homework section of the forums. From a mental ray diagram, I think the image is upright, shrunken and is a virtual image on the same side of the lens as the object.
It is really quite simple. Use the lens equation: [tex] \frac{1}{s_0} + \frac{1}{s_i} = \frac{1}{f} [/tex] The only things you must be careful about are the signs (+,-) of your quantities. Do we count a concave lens as negative or positive? Look that up in your notes (and read about the lens equation). |
| Mar22-05, 08:28 AM | #5 |
oh right,thanks,that was really helpfull...so would the equation turn out like this: 1/f = 1/u +1/V 1/18 = 1/u + 1/24 u = 1/72 so is this the image distance?? or should the lengths have been in Metres?? and also how do i work out the magnification?? |
| Mar22-05, 08:30 AM | #6 |
1/f = 1/u + 1/v is that correct?? i dont know if the concave lens is positive or negative,it doesnt say in the question?? |
| Mar22-05, 08:43 AM | #7 |
When it comes to magnification, what`s happened? The image has changed scale, so it`s a question about proportions! have a think and if you can work it out ... |
| Mar22-05, 08:49 AM | #8 |
For the "real is positive" convention: both f and R are positive for concave mirrors/lenses (real focus) both f and R are negative for convex mirrors/lenses (virtual focus) u is positive for real objects and negative for virtual objects v is positive for real images and negative for virtual images this becomes very important when you start putting more than one lense in a system! |
| Mar22-05, 02:13 PM | #9 |
| Mar22-05, 02:18 PM | #10 |
| Mar22-05, 02:20 PM | #11 |
Maybe the language I used confused you, sorry
If the object is 24 cm away from the lense and the image formed is 72cam away then, the magnification is the relationship between the two distances, [tex] - \frac {72}{24} = -3 [/tex] you can also do it if you know the heights of the image and object basically [tex] Mag = \frac{image height}{object height}= - \frac {v}{u} [/tex] |
| Mar22-05, 02:28 PM | #12 |
R is the radius of a mirror, sorry (again) I should have explained all the terms |
| Mar23-05, 05:49 AM | #13 |
| Mar23-05, 05:52 AM | #14 |
| Mar23-05, 07:51 AM | #15 |
Ok first I must readdress an errror I made! I gave you the wrong sign convention! Ooops
So ... for the Real is positive convention ; f is positive for a convex lense (real focus) f is negative for a concave lense (virtual focus) u is positive for real objects and negative for virtual objects v is positive for real images and negative for virtual images so your lense equation should look like this [tex] - \frac {1}{18} = \frac{1}{24} + \frac {1}{v} [/tex] giving you an answer of v = -72 cm (not 1/72) the minus sign indicates that the image formed is virtual (as it would be for ALL concave lense images!) the magnification therefore goes ike this; [tex] Mag = - \frac {-72}{24} = +3 [/tex] therefore you have an image 3 times bigger than the object i`ve attached a ray diagram to help keep practising it will become natural soon as you`ve allready got a good understanding of optics! A my idol once said " Optics are either very easy or very hard" - Richard Feynman |
| Mar23-05, 10:00 AM | #16 |
| Mar23-05, 10:06 AM | #17 |
Also you have written v = -72......but i thought we were working out u??
sorry,ive confused myself again. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Lens
| "Lens 1.0" - the decision of the problems on optical lens | Programming & Comp Sci | 0 | ||
| Lens | Introductory Physics Homework | 2 | ||
| Lens | Introductory Physics Homework | 1 | ||
| Focal length of concave lens using convex lens | Introductory Physics Homework | 3 | ||
| Need Help With Lens!! | Introductory Physics Homework | 6 | ||
