Designing an op-amp given the output formula
The discussion revolves around designing an operational amplifier (op-amp) circuit to achieve a specific output function, Vout = 5*V1 - 4*V2. The focus is on the theoretical and practical aspects of circuit design, including resistor selection and op-amp configurations.
  • Homework-related
  • Some participants express uncertainty about how to approach the design of the op-amp circuit and the selection of resistor values.
  • One participant suggests the use of a summing op-amp configuration and questions whether the subtraction can be accomplished with one or two op-amps.
  • Another participant proposes using one op-amp with feedback to the negative input and applies Kirchhoff's Current Law (KCL) to derive the necessary equations for resistor values.
  • A participant mentions using two resistors, specifically values of 20k and 5k, to achieve the desired output function.
  • Another participant challenges the feasibility of achieving the design with only two resistors and prompts for clarification on the connections of the inputs V1 and V2.
Participants do not reach a consensus on the optimal configuration or the number of resistors required for the design. Multiple approaches and configurations are discussed, indicating ongoing exploration and uncertainty.
There are unresolved questions regarding the specific connections of inputs and the implications of using different numbers of resistors in the circuit design.
rasen58
Design an op-amp based circuit to produce the function
Vout = 5*V1 - 4*V2
I have no idea how to approach this. I know there are two voltages on the two inputs, and that the feedback resistors should be going to the negative input, but how do I pick the values for the resistors?
Vout = 5*V1 - 4*V2
What opamp configurations are you familiar with? Have you worked with the summing opamp configuration? Can you think of a way to do this subtraction all with one opamp? How about with two opamps?
I think I got it. I can use one op amp and there is a voltage source on each input. So using feedback to the negative side, I can use KCL on the node there and once rearranging that equation, I tried values for the two resistors to make them equal the equation.
How many resistors in total you plan to use?
I used 2: one was 20k and the other was 5k
If you can do that with only 2 resistors you are a genius!
So where are your two inputs V1 and V2 connected?
(Hint: try 4).
  • · Replies 21 ·
  • · Replies 44 ·
