Graviphoton - Repulsion between Matter and Antimatter
The discussion centers around the concept of the graviphoton, a theoretical particle proposed as a symmetry partner to the graviton, and its potential role in mediating repulsion between matter and antimatter. Participants explore the implications of this idea within the context of supersymmetry and gravitational interactions, while questioning the validity and observational status of these concepts.
  • Some participants propose that the graviphoton could cause repulsion between matter and antimatter, though this idea remains unconfirmed.
  • Others argue that since neither gravitons nor supersymmetry have been confirmed, the effects attributed to the graviphoton are questionable.
  • A participant requests clarification on the term "symmetry partner" and seeks sources to better understand the concept.
  • One participant explains that if the graviphoton exists, it would mediate a new interaction related to gravitational strength, suggesting that like charges would repel while opposite charges would attract.
  • Another participant discusses the challenges of constructing gravitational-strength interactions for gravivectors and graviscalars, emphasizing the complexity of dimensional analysis in these theories.
  • There is mention of the gravitino and its potential interactions, with a participant noting that it would not produce "fifth force" interactions due to its mass and the nature of supersymmetry breaking.
  • Some participants express skepticism about the feasibility of the graviphoton and its implications for gravitational interactions, particularly in relation to existing theories.
  • It is noted that graviphotons are considered theoretical and have not been validated experimentally, with some models associating them with dark energy.
Participants express a range of views, with some supporting the idea of the graviphoton and its proposed effects, while others challenge its validity and the underlying theories. The discussion remains unresolved, with no consensus on the existence or implications of the graviphoton.
Limitations include the unconfirmed status of gravitons and supersymmetry, as well as the speculative nature of the graviphoton and its interactions. The discussion also highlights the complexity of constructing theoretical frameworks for new gravitational interactions.
Johnleprekan
Gravitons are suppose to mediate the gravitational force, but there is also the graviphoton which is the graviton's symmetry partner. The graviphoton causes repulsion between matter and antimatter but this is not confirmed. Can someone explain in layman's terms how this particle could do this?
Neither gravitons nor supersymmetry are confirmed, so how could an effect of a particle which requires both be observed?
If you can find a layman's description how photons can attract opposite and repel same charges, it is probably easy to transfer this. In other words: I don't think this is possible.
Symmetry partner? I don't get what you mean. Could you please link to whatever you are using as a source?
The likes of supergravity and Kaluza-Klein compactification can produce several graviton relatives:
Spin 2: the graviton itself
Spin 3/2: the gravitino, a result of supergravity -- supersymmetric gravity
Spin 1: the gravivector or graviphoton, a result of "extended supergravity" and Kaluza-Klein
Spin 1/2: (?), likewise
Spin 0: the graviscalar or radion, likewise
I looked it up here http://en.wikipedia.org/wiki/Antigravity
By symmetry, I mean supersymmetry where fermions have an opposite boson partner and vice versa.
I am aware it has not been observed, but thought there might some theories as to how it could work.
That wikipedia article is somewhat misleading. What is true is that, if the graviphoton exists, it mediates a new interaction with a strength that is related by supersymmetry to the strength of the gravitational interaction. However particles will still have some charge under this new interaction. If it is analogous to the U(1) electromagnetism, then an antiparticle will have an opposite charge with respect to the corresponding particle. As mfb wrote, opposite charges will attract, while like charges will repel. So the graviphoton will lead to a repulsive matter-matter interaction and an attractive matter-antimatter interaction, as long as we are considering particles of the same type. In this way, there will be a new repulsive force comparable to gravity between two protons, but a proton and antiproton will still attract both gravitationally and via the new interaction..
Thank you.
A gravitino won't produce any "fifth force" interactions, for two reasons.
Its mass is at least a TeV because of supersymmetry breaking, making its interaction range at most about 10-18 m.
Emitting or absorbing a gravitino would change a particle into its supersymmetry partner.
If two particles continuously interact by gravitino exchange, they would get put into a mixed state with their supersymmetry partners: (a,b) + (a',b') where a <-> a' and b <-> b'.
The same goes for gravispinors, as they might be called, spin-1/2 particles related to the graviton by extended supersymmetry.
There are other problems, like how one constructs gravitational-strength interactions for gravivectors and graviscalars.
One can see where the problem will be by doing dimensional analysis of possible interactions. One sets hbar = c = 1 and finds what powers of mass the coupling constants are. Mass = 1/length in these units. I'll be doing the calculations for 4D space-time, but they can be extended to additional dimensions.
The field is given by D2(field) = (coupling constant) * (source density)
and the resulting potential energy is (field) * (source density) integrated over 3-volume.
If the source current has dimension L-s or Ms, then the coupling constant has dimension M6-s.
For electromagnetism and similar theories, the current has dimension L-3, since its integral over volume is a dimensionless number in hbar = c =1 units. That means that the electric charge and other gauge "charges" are dimensionless.
For gravity, the current is the energy-momentum tensor, an energy/momentum density/flux. Its dimension is M*L-3 = M4. The coupling constant has dimension M-2, in agreement with
(gravitational constant) = 1/(Planck mass)2
So one has to construct currents with dimension M4 for the gravivector and the gravivector.
For the graviscalar, there's a current that's very easy and gravity-related. Contract the energy-momentum tensor over its indices, giving
(mass/energy density) - 3*pressure.
For the gravivector, it's much more difficult. I've done a lot of searching, and I can't find what would be a sensible sort of source current.
One can construct (some mass) * (gauge-theory vector current)
where (gauge-theory vector current) is what one gets out of electromagnetism, for instance. For an elementary-fermion field, that current is
[itex]j^\mu = {\bar\psi} \gamma^\mu \psi[/itex]
What would be an appropriate mass here?
But this sort of term has the property that matter-antimatter interchange will reverse its sign, unlike the case for gravity and my graviscalar interaction. It will also yield the "mass"
[itex]M_{gravivector} = \sum_{flavor\ i} m_{(i)} N_i[/itex]
where Ni is the number of elementary fermions with flavor i (ordinary particles - antiparticles), and m(i) is the mass value associated with flavor i.
For an atom with Z protons and N neutrons, this gives us
Mgravivector = m(electron)*Z + m(up quark)(2Z+N) + m(down quark)(Z+2N)
Photons and gluons don't enter, because they are their own antiparticles.
The overall mass is approximately mnucleon(Z+N)
The average N/Z is 0 for hydrogen-1, 1 for the lighter elements, and greater than 1 for the heavier elements, going up to 1.5 near uranium.
So the ratio of these masses is about the ratio of m(flavor) for electrons, up quarks, and down quarks to mnucleon.
Graviphotons are superpartners of gravitons. They can produce both attractive and repulsive gravitational forces. This is a completely theoretical concept and hasnt been validated experimentally. Graviphoton in some models are considered a part of dark energy
  • · Replies 34 ·
  • · Replies 37 ·
