MIPS assembly programming - converting integer to decimal/binary
The forum discussion focuses on creating a MIPS assembly function that converts an integer to either decimal or binary format based on a specified base (2 for binary, 10 for decimal). The proposed solution involves repeatedly dividing the integer by the base and storing the remainders, which represent the digits in reverse order. Additionally, the implementation must account for negative integers, requiring extra logic to handle signed numbers. This approach allows for a single function to manage both conversions efficiently.
  • Understanding of MIPS assembly language syntax and structure
  • Knowledge of integer division and remainder operations
  • Familiarity with handling signed integers in programming
  • Experience with stack operations and array manipulation in assembly
  • Research MIPS assembly division and modulus instructions
  • Learn about signed integer representation in MIPS
  • Explore stack management techniques in MIPS assembly
  • Study algorithms for converting numbers between bases
This discussion is beneficial for MIPS assembly programmers, computer science students learning low-level programming, and anyone interested in number base conversions within assembly language.
colerelm
I'm writing a MIPS assembly program and I'm trying to figure out a way to display a given integer in either decimal or binary using only one function with two parameters. The function takes in two parameters: an integer and a base (either '2' or '10'). I'd like to not edit anything other than just this one function.
Can anyone help me create such a function? I can't wrap my head around the logic needed to do so using assembly language.
Thanks in advance.
Technology news on Phys.org
You can get the digits in reverse order by repeatedly dividing the integer or the quotient from the previous division by the base (2 or 10), and saving the remainders (into an array or push them onto the stack), which will contain the digits (in reverse order). You'll need some extra code to handle negative numbers as signed numbers.
  • · Replies 102 ·
  • · Replies 25 ·
11K
  • · Replies 16 ·
  • · Replies 20 ·
