Slotted ALOHA P(All nodes successful @ time t)
  • Context: Undergrad
  • Thread starter Thread starter testietester
    Nodes Time
The discussion revolves around the probabilities associated with the slotted ALOHA protocol, specifically focusing on the likelihood of multiple nodes successfully transmitting frames without collisions over a series of time slots. Participants explore the mathematical formulations for calculating these probabilities, particularly in scenarios with different numbers of nodes and time slots.
  • One participant presents two different approaches to calculate the probability of all nodes successfully transmitting at time 3, using different formulations based on the probability of success and failure.
  • Another participant suggests considering all possible orders of successful transmissions, noting that there are 6 possible orders for 3 nodes and proposes a formula based on permutations.
  • A later reply clarifies the meaning of extending the analysis to time slot 4, indicating that the probability must account for various scenarios of nodes choosing not to send or experiencing collisions.
  • There is a question regarding the interpretation of the probability expression p(1-p)(1-p), with participants discussing its meaning in the context of one node transmitting while the others remain silent.
  • Concerns are raised about the calculated probability being low when substituting p=0.5 into the proposed formulas, prompting further inquiry into the validity of the analysis.
Participants express differing views on the correct formulation for calculating the probabilities, with no consensus reached on which approach is accurate or preferable. The discussion remains unresolved regarding the best method to extend the analysis to additional time slots.
Participants highlight the complexity of the slotted ALOHA protocol, noting that the analysis may differ based on whether it is treated as a discrete time process or a continuous one. There are also unresolved assumptions regarding the impact of collisions and the probability of nodes choosing to send.
testietester
I'm trying to understand slotted ALOHA and I have a question regarding the probabilities.
Here is an example: I have 3 nodes, ready to send a frame each. The probability of them sending = 0.5. What is the probability that at time 3 (3 time slots later) they will have all been successful? I know that: P(given node successful) = p(1-p)^(N-1) P(any node successful) = Np(1-p)^(N-1)
I have a couple versions of the answer and I'm not sure which one is correct(or none at all):
1) P(node 1 success) + P(node 2 " ") + P(node 3 " ") = 3*[0.5(1-0.5)^(3-1)] = 3/8
OR
2) P(1 node successful) * P(next node " ") * P(last node " ") = 3(0.5)(0.5)^(3-1) * 2(0.5)(0.5)^(2-1) * 1(0.5)(0.5)^(1-1)
I'm leaning towards version 2 of my answer, but I don't see how to extend it to t = 4.
I don't remember much from my discrete math days. But I'm leaning towards the first one(or a variation of the first one). Please help me clear this up.
Thanks for looking!
In case you didn't know slotted ALOHA works like this:
You have nodes, ready to send "frames" of data. They send every time slot, but when more than one node sends on the same time slot there is a collision and the frames don't make it to its destination. That is why every node sends at the beginning of every time slot based on a certain probability. If there is another crash, the nodes involved resend their frames based on probability p. This continues until eventually only 1 frame is expressed on a time slot, and it is sent successfully.
If the nodes are numbered 1,2,3 then you can consider all possible orders in which they succeed. There are 3! = (3)(2)(1)=6 possible orders. For each order (such as 2,1,3) the probability of that sequence of successes is the same. Its p(1-p)(1-p) p(1-p)(1-p) p(1-p)(1-p). (For example, if you wrote the factors for the sequence of successes 2,1,3 in order, they would be ((1-p)p(1-p)) ((p)(1-p)(1-p)) ((1-p)(1-p)p) and these factors can be rearranged.) The probability of success is the sum of the probabilities of success in particular ways, so it is 3! (p(1-p)(1-p))^3.
When you say "extend to t=4", do you mean to extend both the number of nodes and the number of time steps?
@ Stephen Tashi
Thanks for the reply. By t=4 I mean the time slots have been extended to 4. There are still 3 nodes with a frame to send. But, we now have 4 time slots to get them all sent.
Because failures can happen because of collisions, or simply because nodes choose not to send(they send with probability p) I would have to OR(add) in the cases where the first slot empty, 2nd slot empty, and 3rd slot empty. The 1 and 2 slot can be empty due to collisions/choosing not to send. But the only way for the 3rd to be empty is just choosing not to send. I think...
Also, why is it p(1-p)(1-p)? Plugging in p=0.5 gives 3!(0.5(0.5)(0.5))^3 = 0.01171875. Seems a little low.
Thanks again!
What do you mean by "it"? p(1-p)(1-p) represents the probability of one node transmitting in a time slot and the other two being quiet.
I don't know what you are comparing this number to. I glanced at documents on the web that analyze "slotted ALOHA" and they analyze it as a continuous process, not as a synchronous process that proceeds in time steps. So your analysis isn't an analysis of what the web calls "slotted ALOHA".
  • · Replies 21 ·
