Finding Potential Energy for a Chain on Pulley System
The discussion focuses on deriving the Lagrangian for a uniform flexible chain of mass M and length L suspended over a frictional pulley with radius a and moment of inertia I. The user is attempting to establish a constraint equation involving the generalized coordinate l, which represents the displacement below the axle of one end of the chain. The key challenge identified is calculating the potential energy of the system, particularly determining the center of mass (CM) for the chain, which can be divided into three segments: two hanging pieces and a semicircular piece. The CM can be calculated using the formula for the weighted average of the positions of the individual segments.
  • Understanding of Lagrangian mechanics
  • Knowledge of potential and kinetic energy concepts
  • Familiarity with center of mass calculations
  • Basic principles of rotational dynamics
  • Study Lagrangian mechanics in detail, focusing on systems with constraints
  • Learn about calculating the center of mass for composite bodies
  • Explore rotational kinetic energy and its application in dynamic systems
  • Investigate potential energy calculations in gravitational fields
Students and professionals in physics, particularly those studying mechanics, as well as engineers working with dynamic systems involving pulleys and chains.
starryskiesx
Hi there,
I'm having some problems trying to write down the Lagrangian of the following system:
A uniform flexible chain of mass M and length L is hung under gravity on a frictional pulley of radius a and moment of inertia I whose axle is fixed at a point above the ground. Write down the Lagrangian of the system using the generalised coordinate l denoting the displacement below the axle of one end of the chain. You may assume that L is sufficiently long enough so that some part of the chain hangs freely from both sides of the pulley.
So I've tried to make a constraint equation: I thought L = pi*a + l + l' where l and l' are the displacements below the axle of each end of the chain.
I'm also thinking the kinetic energy should be easy, we have a rotational kinetic energy from the pulley and also a translational kinetic energy from the motion of the chain.
The real problem is trying to write down what the potential energy of the system is, I'm getting confused about where the centre of mass will be.
Any suggestions? Thank you!
You can break down the mass of the chain into three pieces: hanging piece 1 of length ##l'##, hanging piece 2 of length ##l## and the semicircular piece 3 of length ##\pi a##. It should be easy to find the CM of each piece separately. Then the CM of the whole chain will be given by the usual equation $$\vec R=\frac{m_1\vec r_1+m_2\vec r_2+m_3\vec r_3}{m_1+m_2+m_3}.$$
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 16 ·
