Is space-time discrete or continuum?
The discussion centers on the nature of space-time, specifically whether it is discrete or continuous. Participants explore theoretical implications, observational evidence, and various models, including loop quantum gravity and concepts related to Planck units.
  • Some participants question whether the Planck scale implies a discrete nature of space-time, suggesting that if the smallest possible scale is Planck's length and time, then movements could be viewed as discrete steps.
  • Others argue that tests have not provided evidence for quantized space-time, citing predictions related to high energy photons that have not been observed.
  • A participant discusses the relationship between continuous systems and discrete modeling, suggesting that discrete approximations can be used to simulate physical systems, potentially aligning with Planck units.
  • Some participants note that loop quantum gravity (LQG) quantizes area and volume but not length, raising questions about the implications of Lorentz contraction on these quantizations.
  • There is mention of the Bekenstein bound as a limit on information storage in space, which some argue supports the idea of discrete space-time.
  • Another perspective suggests that continuous and discrete characteristics of space-time might coexist, referencing information theory and sampling theorems.
  • One participant highlights a contradiction between relativity and the Planck length, discussing how different observers might perceive quantum gravity effects differently, which could conflict with the principles of relativity.
Participants express multiple competing views on whether space-time is discrete or continuous, with no consensus reached. The discussion remains unresolved with various hypotheses and arguments presented.
Some claims rely on assumptions about the nature of physical laws and the implications of quantization, while others depend on the interpretation of observational evidence, which remains lacking in definitive support for any model.
Boy@n
Is there a way to know one way or another?
If smallest possible scale is Planck scale, does it mean that space-time is discrete where smallest possible step is Planck's length (PL) and smallest possible time is Planck's time (PT)?
If I move my hand from point A to point B, say 1m exactly in 1s, how many steps have I made? 1m/PL and for each step I spent PT? So, from that viewpoint my hand made those steps with the speed of light?
Tests to date have failed to reveal evidence of quantized space time. One of the early predictions of this model was that high energy photons from distant sources should arrive at Earth at different times than low energy photons. Another was there should be differences in the airy disc between high and low energy photons. Neither effect was detected. The notion is still entertained in some models of loop quantum gravity, but, observational evidence remains lacking.
this is musing from an electrical engineer that knows something about discrete modeling of analog or continuous-time systems.
systems that are continuous are often described by continuous differential equations. if the diff eqs. are linear, there is a way (using Laplace Transform) to describe the system exactly and solve for a closed-form solution. but if the system has little non-linear components in them, sometimes the only way to understand the system is to simulate it with a discrete-time approximation. probably the simplest discrete-time approximation is Euler's forward method . now when programming a computer to simulate a physical system will involve turning those differential equations into difference equations, using, say the Euler method. in doing so you will compute dimensionless constants that will serve as coefficients in the discrete-time simulation. the sampling period and other time parameters will play a role in these dimensionless coefficients.
similar to cellular automata, you can take equations of physical interaction, like Maxwell's equations, and Schrödinger, and Einstein's field equation, and continuity equations for conserved quantities of physical stuff, and you can turn them into difference equations that will involve the sampling period (in the time dimension) of the simulation and cell size (in the 3 length dimensions).
now if you were to select a quantization unit in time and length that were essentially the Planck units, but defined so that these constants are removed from the above equations of physical law (which means these constants are set to 1): [itex]4 \pi G = c = \hbar = \epsilon_0 = 1[/itex], then when you turn the differential equations into simple difference equations (Eulers method is plenty adequate because the discrete time and cell width are virtually infinitesimally small). but because these constants of nature disappear from expressions of physical law, there are no arbitrary scaling constants in the discrete-time simulator. we don't have Nature taking this quantity of flux density and pulling this number ([itex]\frac{1}{\epsilon_0}[/itex]) out of her butt and scaling it to convert it into field strength. their quantities are equal so then maybe they, the two physical quantities, are the same thing. maybe flux density is the very same thing as field strength in Maxwells equations as well as the discrete-time simulation of it.
but that happens (ditch the arbitrary scaling constants) only if you run your discrete-time, discrete-space simulator with discrete units of the rationalized Planck time and Planck length (where [itex]4 \pi G = c = \hbar = \epsilon_0 = 1[/itex] ).
because the Planck scale is soooo... ridiculously tiny, there is no way human beings can ever hope to measure anything around that scale to observe any of this discrete phenomena. way smaller than anything in the atomic or subatomic scale. so i like to pretend it could be true. i don't think there is any way to find out one way or another.
Even if LQG is correct, LQG quantizes area and volume, not length. Length quantization is not possible because a given length can be arbitrarily contracted by Lorentz contractions.
don't the Lorentz contractions also affect area and volume? how can it not?
It is not even clear whether all models based in discrete spacetime structure do predict deviations from continuum models as tested in these experiments. Afaik LQG as of today does not predict any new disperison relation.
Here are some views:
Space is discrete:
associated with Planck units which clearly implies a discreteness:
...adding one bit of information will increase the horizon of any black hole by one
Planck unit of area, or one square Planck unit. Somehow, hidden in the principles of quantum mechanics and the General Theory of Relativity there is a mysterious connection between individual bits of information and Planck sized bits of area.
so says Leonard Susskind, THE BLACK HOLE WAR, page 154
The following is a paraphrase of an argument for the discreteness of spacetime, made by Smolin in his popular-level book Three Roads to Quantum Gravity.
The Bekenstein bound says there's a limit on how much information can be stored within a given region of space. If spacetime could be described by continuous classical fields with infinitely many degrees of freedom, then there would be no such limit. Therefore spacetime is discrete.
There is no distinction between continuous and discrete:
http://arxiv.org/abs/1010.4354
“The equivalence of continuous and discrete information, which is of key importance in information theory, is established by Shannon sampling theory: of any band limited signal it suffices to record discrete samples to be able to perfectly reconstruct it everywhere, if the samples are taken at a rate of at least twice the band limit. It is known that physical fields on generic curved spaces obey a sampling theorem if they possesses an ultraviolet cutoff.”
http://pirsa.org/09090005/
Spacetime can be simultaneously discrete and continuous, in the same way that information can.
Good discussion in these forums here:
https://www.physicsforums.com/showthread.php?t=391989
https://www.physicsforums.com/showthread.php?p=3558771#post3558771
and one more perspective...
There is a well known contradiction between relativity and Planck length:
[Wikipedia explains the contradiction nicely:
http://en.wikipedia.org/wiki/Double_special_relativity
If Special Relativity is to hold up exactly to this (Planck) scale, different observers would observe Quantum Gravity effects at different scales, due to the Lorentz-FitzGerald contraction, in contradiction to the principle that all inertial observers should be able to describe phenomena by the same physical laws.
Yet the energy density of empty space is believed to have a positive value and apparently this cosmological constant of
"...universal energy density would have the same value for all observers, no matter where or when they made their observations no matter how they moved."
(which is why Einstein called it a cosmological "constant")
Why can't you do the same for a given area by arbitrarily contracting one side?
There is a common misconception regarding area-quantization in LQG. The area-operator with discrete spectrum is not a physical Dirac-observable, so it can't be used to classify physical states; or the other way round: its eigenstates carrying discrete area are not physical states. So physical states which are solutions to all three constraints Gauß G, Diffeomorphism D and Hamiltonian H have not yet been constructed (due to H!) and could very well carry continuous area!
Look at a discrete basis like the harmonic oscillator states |n>. They can be used for every problem constructed in an L2[-∞,+∞] Hilbert space. But the conclusion that discrete basis states |n> with discrete energy n+1/2 do exist, does not mean that every physical problem constructed in this Hilbert space must have discrete energy levels (the situation is even more complicated b/c in the case of LQG the operator used to construct the eigenstates is not an observable like energy in the harmonic oscillator case)
So what one has to do is to construct a physical observable "area" and calculate it's spectrum. I do not know whether this has already been achieved, but I guess the Erlangen / Thiemann has done some relevant work, especially for physical constuctions getting rid of diffemorphism invariance using "dust fields" or "obsever fields".
Global Lorentz covariance is not a symmetry of general relativity; observers classified according to SR
are not well-defined in GR. Taking diffeomorphism invariance into account everything fits nicely. The strange idea is that 'discrete spacetime' is often treated as equivalent with fixed lattice-like structure. This is wrong. All approaches using discrete models like LQG, CDT do not rely on a fixed structure; of course the is no fixed structure! The structure is a) arbitrary due to diffeomorphism invariance and therefore locally obsever-dependent and b) subject to renormalization and therefore unphysical.
I think that this is not correct. This can be seen quite easily if the cosmological constant becomes part of the energy-momentum tensor Tab as "dark energy"; of course this term is observer dependent! This is trivial b/c T is subject to local coordinate transformations, and these do affect the metric term cc * gab as well. The reason why nobody cares about this is that in cosmology one always uses one fixed reference frame, namely a single solution to the Einstein field equations with highest degree of symmetry. But if you consider a local observer moving with some speed v relative to a fixed background metric (i.e. DeSitter space with cc) this observer would observe a different T', i.e. a different (cc * gab)'. Of course the value of cc is not affected, but the local energy density cc * g00 is.
Boy@n said:
... and smallest possible time is Planck's time (PT)?
In previous discussions on this forum it has been stated that if time IS quantized, then the quanta is MUCH less than the Plank Time. I do not say that with any authority, I'm just repeating what I've heard here and I do not recall the rationale for that assertion.
On the issue of quantized geometry and Lorentz contractions..
the basic argument is that one cannot have quantized values as we should be able to reduce them continuously further by performing a Lorentz transformation. The flaw in this argument is that we are not dealing with classical quantities, but rather quantum observables. The resolution then follows from the fact that the length operator, L, in the original frame does not commute with the length operator, L', in the transformed frame: they do not have simultaneous eigenstates - an eigenstate of L is not an eigenstate of L', rather it is a quantum superposition of eigenstates of L'. The eigenvalues of L' will be the same as the (discrete) eigenvalues of L: it is the expectation value of L' that will be Lorentz contracted in a continuous manner.
There was some controversy about eigenvalues being discrete or continuous:
"Are the spectra of geometrical operators in Loop Quantum Gravity really discrete?" by Dittrich and Thiemann - http://uk.arxiv.org/pdf/0708.1721.
Rebuked by Rovelli in "Comment on "Are the spectra of geometrical operators in Loop Quantum Gravity really discrete?" by B. Dittrich and T. Thiemann" - http://uk.arxiv.org/pdf/0708.2481.
Another common misconception is the idea that discrete spacetime or eigenvalues will necessarily violate local Lorentz / Diffeomorphism invariance. Of course this need not be the case b/c
- these symmetries can be recovered in a continuum limit / renormalization flow (like lattice gauge theory)
- violations can be restricted to the unphysical sectors
- discrete eigenvalues for angular momentum in QM do not violate rotational invariance
Yep, by exactly the same argument I gave above.
Rovelli, from the above paper, seems to conclude:
... the evidence remains strong towards the conclusion that LQG implies fundamental
discreteness at Planck scale...
well technically there's no definite answer some physicists say that time & motion don't exist that every thing that has ever happened is simply all existing I would suggest Julian Barbour's "The End of Time" if you want to pursue this idea further its a good book
I am considering to buy this book (ebook if possible). I've read some reviews, saw his website (with ideas) and description of his paper on Shape Dynamics.
All of it looks very interesting and convincing... Anyone else want to comment on the ideas presented by Barbour, and on his book?
I didn't read the book but I did read the "Shape Dynamics" document you have linked above.
Your question on discretness is inspiring me some spontaneous thoughts:
A)
- We perceive that our local neighbourhood has what we have called "dimensions" which are in fact independent directions: length, width, height and time.
- Any concrete progress needs the realization of measurements. This is obliging us to introduce an instrument measuring, e.g. the lengths. But not only that. With that instrument, we must make the choice of a unit, a norm. (My room is x meter long)
- The norm itself introduces a potential discontinuity (because it has a fixed value), except if the mesure x is/can be continouus.
Conclusion: the discretness is mathematical set-independent!
B)
Mathematics symbolizing what I have tried to described in A) are related to geometry (ds)2 = gab. dxa. dxb). Well, but there are many, many ways to mesure the same length/surface/volume... depending on a method, on the norm we have choosen, on the "form"(topology) of the object we are measuring. The lattice structure that we are in some way projecting into the real world we are living in and which we are trying to measure is something artificial, even if very practical. This is a pragmatic projection of our inner understanding of the world that we are perceiving.
Conclusion: if geometry is the science measuring the geography/topology, then the results (discretness or not: your question) will be highly tool-independent, even if the topos is itself discontinous (example: if the ladder is longer than the gape, you will never remark that were skying over the gape and risking your life!)
C)
Coming back to the "Shape Dynamics". This is an interesting approach which I relate to the ADM procedure. I am not totally certain to have catched the essence. Does it mean (see § 4.1, § 4.2) that a history (e.g. of a particle) is equivalent to a set of slicing of the 4D spacetime (i.e.: a set of successive hypersurfaces)? If yes, then the equation of motion of the described particle must be itself the constraint imposing the manner how the 4D space must be sliced... (sorry speculation)
Great book its a little weird starting out but if you keep pushing on the ideas start to sink in I would recommend it. I'll have to look at his other work it looks quite interesting!
I have always wondered about this myself :)
If spacetime itself would be quantized wouldn't it lead to quantisation of angular momentum and energy ?
Also would it be evidence for the "universe simulation" theory ? ;)
I personally "feel" like it should be quantized ^^
those are quantized...h [Planck's constant] is the quantum of action. Discrete energy levels of electron orbitals is an example.
What would quantized geometry/gravity do to the topology of spacetime? Does QG destroy topology?
I am sure no expert on topology...but one theory does not necessarily destroy another. If general relativity works pretty well [based on our observations so far] using a continuous pseudo-Riemannian manifold, another theory with discrete spacetime, like quantum gravity, could provide a more wide ranging model...it could extend the range of classical GR to cover black hole and big bang singularities, for example. Or it might just explain those, analogous to how we currrently use quantum mechanics for many small scale phenomena and GR for cosmological scales.
If 'quantum gravity' were to fully describe the quantum behavior of the gravitational field it might or might not be very applicable to large scale gravitational field behavior. The two problems could be connected (as assumed in string theory) or could be separated (as assumed in loop quantum gravity).
For example, if the metric is quantized, then wouldn't neighborhoods around points be quantized. And if neighborhoods are quantized, then would the Hausdorff property still hold on which manifolds (and therefore GR) rest?
look here, friend, I do not even know what a Hausdorff property is...[really!]
but a quick skim here
http://en.wikipedia.org/wiki/Hausdorff_property
Code:
Almost all spaces encountered in analysis are Hausdorff; most importantly, the real numbers (under the standard metric topology on real numbers) are a Hausdorff space. More generally, all metric spaces are Hausdorff.
and here
http://en.wikipedia.org/wiki/Metric_space
In mathematics, a metric space is a set where a notion of distance (called a metric) between elements of the set is defined.
which suggests to me...No problem! "Don't worry, be happy, mon"
but check those out yourself...
When you think of Hausdorff, you can think of "house" dorff. This is the property where each point in the topology can be enclosed in a neighborhood that does not include any other point you may choose. Even if you choose points very close together, you can always construct even smaller neighborhoods that exclude the other point you chose. No matter how close you choose the points, they each have their own little house to dwell in.
But if the metric is quantized and with it areas, then you cannot always construct a neighborhood that excludes a close point. The property of Hausdorff could not apply to such a space, and it would not be a manifold. Then since GR is constructed on manifolds, GR would not be applicable, right?
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 23 ·
